Question about Vizio Televison & Video
Model VO370M S/N LUKEBAK2106528 PART #10225100022 I purchased 5 of this model from Buy .com One of the TV's will no longer work with the remote . I tried this remote on another set and it works . The TV also has white horizontal lines making the picture distorted .
Edgextreme
SOURCE: Horizontal lines
I have the same problem with my camera and it appears to be a well known problem with this camera and some others models beside of canon's: The problem appears to be caused by a defective CCD integrated in the camera. The CCD is not very resistant to various enviromental factors such as humidity and changes of temperature, causing the "porcelain" cover of the CCD "brake" and make a contact failure or something like that. The fact is that Canon, Sony and some other brands annouced CCD Repair "or" replacement programs totally free of charge to the cameras presenting this problem. To identify if this is your problem, your camera must show at least one of these symptoms: *The images in screen LCD present/display a very noticeable dye towards some color. *The screen is completely black. *The images are corrupted or distorted. *The images have horizontal lines or bands. *The images have vertical lines or bands. - The problem appears because the type of glue that was used in the manufacture on the part of Sony, is sensible to the heat and the humidity, causing that the sensor separates of its base and creating failures in the connectors of the CCD. In a publication made by Canon Asia they annouce: Affected products that exhibit this phenomenon will be repaired free of charge, regardless of the warranty status, if disconnection of the internal wiring of the CCD is confirmed. which means, that at least in these places, Canon will free repair the cameras affected by this problem after even expired the guarantee. I hope this information is useful for you. Please rate my solution. Anyway you can check these sites up (in spanish but try google translator): http://www.faq-mac.com/mt/archives/020325.php http://www.foto-digital.com.mx/2005/10/14/konica-minolta-notifica-problemas-en-camaras/ http://www.ayerpm.cl/victor/blog
Posted on Feb 05, 2007
  • 45 Answers
SOURCE: Nopicture
No vertical deflection. Vertical output IC, caps.
Posted on Nov 25, 2007
HDTV GURU
  • 261 Answers
SOURCE: Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
  • 3422 Answers
SOURCE: TLM 2619 MODEL-DISPLAY PROBLEM
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $250 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Goodluck..
Posted on Feb 21, 2008
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
I need a vizio vo370M schematic diagram
has anyone found a place to buy a t2d diode 94 or t2d 94 diode for a vizio vo370m power supply board, placment d106
Dec 09, 2011 | Vizio VO370M LCD TV
Where can I purchase a remote for my GE Tv model 35GT720 the remote I have no longer work
You can purchase a universal remote that works with all sets at any Walmart, Target, Sears, Best Buy, Big Lots, Radio Shak ect. They come with instructions on how to program the remote to work with your model television set. Universal remotes also control DVD players, VCR's, Cable TV ect.
Jul 06, 2011 | GE 35GT720 35" TV
What is the TV remote control code for a VIZIO TV set model number V0370M
hi! i have a couple of codes for your TV, just try them, 1343, 1489,
1004, 1429, 1433, 1439, hope this helps! goodluck!
Apr 07, 2010 | Vizio VO370M LCD TV
I lost my remote control to my TV panasonic PV DF2700. I have a RCA universal control, Is there a code to program this tv to respond to the RCA remote control?
There are a few universal remote controls that you can use, I have 2 philips remotes that work. One is model SRU4106/27, I believe i purchased that last year at Target, the other I no longer have the instructions to and there is no model number on the remote, but if the label says dvr's the remote will probably work. It is nice to get one with an advance button that has an arrow on the button, because Replay tv of that model has a commercial skip that can be used vs fast forward on other dvrs. The remote that I gave the model number for does not have the advance button, but the other thinner gray remote does have it and I purchased that one at Best Buy, but haven't seen them there in a while. You can also find them on ebay, just search replay tv on the search bar...Good Luck!
Jan 12, 2010 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
What are the VIZIO L30e LCD TV codes for a comcast remote control?
I have a vizio vo370m tv with a comcast remote urc1068 need the code to work tv
Oct 10, 2009 | Televison & Video
How do you unlock a rca truflat tv?????
Check out remotes.com or simply buy a universal remote at wal-mart walgreens, radio shack.......
The original remote is no longer available for purchase. http://www.remotes.com/remotes/servlet/rs?uuid=12445202934080&o=c&o=c&a=Search&uid=0&m=20F511T
Sep 09, 2009 | RCA TruFlat 27F520T 27" TV
Can RC65 remote replace the original RCA Remote for DirectTV?
http://shop.ebay.com/items/rca+universal+remote?_dmd=2&_cpr=249 this is a e-bay web page link for purchasing RCA universal remote controls. Here you will find all different makes and models of RCA remote controls. They are for immediate sale and for auction. You should find the model number of your old remote control and put the number into a search engine to find the replacement mode for your television.l.Once you have the model number you can go to the e-bay web page and find the model and purchase it. If you cannot find it there. Use the model number in the search engine to find places to purchase the replacement. I hope this information help you find a replacement remote control for your television. Thank you for using FixYa and have a nice day!
Mar 28, 2009 | RCA DIRECTV Satellite Remote Control
Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
Remote will no longer work
Your best bet is to buy a universal remote that would work with your model television or a replacement remote from your manufacturer.
This one is pretty cheap (and may be your exact remote?)
http://www.replacementremotes.com/store/productdetailp.cfm?productid=28946
You could probably buy a universal remote cheaper at walmart or target, but the cost savings will cost you the time and hassle to program the remote (and if you buy a universal, you must make sure it works with emerson TVs).
May 12, 2008 | Emerson EWF2703 27" TV
Televison & Video Logo
104 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
