Question about JVC Audio Players & Recorders
I have a JVC compact component system CA-V805T, I have long been bought, and after some few years when I wanted to play the CD, the screen just written "Track 1 0:00" and do not want to play I've tried it a third tray but the result is the same I have brought to the nearest JVC dealer and the dealer check it out, the dealer said that my JVC CD player That the IC is damaged, what should I do? Thanks
SOURCE: jvc xlmv33 three tray karaoke cdg player
I took it to a repair shop, found out it would be very hard to fix due to age. could not get parts for it, so I will just get a new one.
Thanks for the suggestion
Posted on May 24, 2009
SOURCE: Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Posted on Jul 31, 2009
  • 4102 Answers
SOURCE: CD CHANGER SAYS NO DISK.
Hi it could be one of two problems it could just be that the laser lense is dirty and you can by a lense cleaning cd for this but dint buy cheap ones as they tend not to work.
If after doing this the same message comes up then the chances are that the laser has failed and would need replacing. The problem with this is it is going to be expensive to get done as its impossible to do yourself as it needs special tools. As for the cost it would be cheaper to replace the whole unit than get the laser repaired.
Try the lense cleaner first as this is the cheapest option usually 9 out of 10 of the times this solves the problem.
Let me know how you get on and if you need further assistance ok..
Posted on Aug 11, 2009
  • 53 Answers
SOURCE: JVC CA-S200. Cd loads but will not play.
laser will be dusty. clean it first.
if no joy then CAREFULLY and remembering where they were... turn up the small orange power control on the back of the laser a bit (1/12th clockwise- NO FURTHER)
and if still no joy then maybe the orange focus offset control on the pcb to the right take it to one end.
If still no joy then the laser is duff
Posted on Nov 07, 2009
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
JVC MX-GT88 sound system showing protected them shut off why
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
Dec 08, 2015 | JVC MX-GT88 CD Shelf System
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
Does not read cd or dvs
Could be many things. But it probably needs a new pick-up (laser). You can try cleaning it with rubbing alcohol on a cotton swab.
Jan 30, 2009 | Audio Players & Recorders
Dec 08, 2008 | Audio Players & Recorders
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
Boombox on standby
i have a jvc compact component system ca-hxd7 an when you trun it on it pop real loud an then read PROTECT then goes off what can we do
Dec 03, 2006 | JVC RC-BX530 Cassette/CD Boombox
97 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
