Question about Juki TL-98QE Mechanical Sewing Machine
Needle keeps breaking when sewing - Juki TL-98QE Mechanical Sewing Machine
  • 340 Answers
Make sure the needle is in correctly. On most machines the flat part goes towards the back of the machine. Also make sure you are using the correct size needle for the type of thread and fabric you are using. Thicker fabrics such as denim and upholstery fabrics will require a thicker needle, like a 100 (16).
Posted on Sep 04, 2010
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
SOURCE: thread keeps breaking
347 singer Bobine setting
Posted on Dec 30, 2007
SOURCE: needle keeps hitting the pressure foot and breaking
your machine probably needs to be retimed.
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
My 2003 Brother sewing machine is needle keep on breaking when I try to sew
http://www.sewingandcraftcorner.com/why-does-my-sewing-machine-needle-keep-breaking
If it continues to break needles, most likely the machine has been knocked out of time. Search for sewing machine timing or take it for repair.
Mar 22, 2017 | Brother Sewing Machines
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
When sewing thread keeps breaking and comes out of the needle
The needle thread breaks
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
Jan 08, 2013 | Yamata Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
My white sewing machine needle keeps breaking.
take it to a sewing machine repair shop, so the needle bar can be checked, & also the timing
Jul 29, 2010 | White Sewing Sewing Machines
My sewing thread keeps breaking, tension is on 4, but even on 2 it still breaks. Kind of fabric doesn't make any difference and I have changed needle.
Have you put your needle in the right way and not back to front. Make sure that the groove in the needle is to the front.
Feb 09, 2010 | Janome 659 Mechanical Sewing Machine
Thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Aug 24, 2009 | Yamata FY700 Mechanical Sewing Machine
Juki TL-98QE Mechanical Sewing Machine Logo
90 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
