Question about HP Pavilion Elite M9060N PC Desktop
Only getting a blue screen
When I turn my pc on, all I get is a blue set up screen and the keyboard flashes. I try to press f1 to enter set up but nothing works
  • Anonymous May 15, 2008
    When I start up My HP it goes to the blue setup screen and then I can't get any farther from there the keyboard doesn't work for a setup menu or a diagnostic check or somthing similar.
    Champion:
  • 207 Answers
hp computer is famous for all these kind of crashes
try these steps
1.) reset the ram (beliving u know how to do it)
2.)check if the keyboard is working or not
if yes reboot the comptur and keep hitting f 8 like taptap
now a black screen will *** select safe mode and try to repire the system
if not order the set of recovery disc
Posted on May 18, 2008
I have a thinkpad x41. Now every time I try to boot I get problems. Sometimes I even don't get the first image (IBM-screen, with message "press the blue IBM-button to enter BIOS", then when I...
According to Lenovo support, error 0211 is a keyboard error - keyboard not working. Ebay sell replacement keyboards for £20 - £30 for your x41 which should hopefully fix this error after fitting.
Apr 14, 2011 | Computers & Internet
Dimension 8300 boots up to a black screen that says "Alert! Storage battery voltage low" Press f1 to continue, f2 to enter set up etc If I press f2 I can use the keyboard to scroll through...
i think storage battery low indicates that the cmos battery is losing its ability to reatin a charge. try replacing it. if that doesn't solve your problem, you have deeper issues. consult a professional if this is the case.
Jan 31, 2011 | Dell Dimension 8300 PC Desktop
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
Aug 10, 2009 | ASUS Computers & Internet
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Can't get into the bios for a presario 4716
This is what the Compaq site had to say about the BIOS utility for your system (Source: Compaq): • • • •You may have difficulty accessing the BIOS Setup utility screen, because you must press a specific key(usually F1) very quickly before the Windows screen appears. If you do not enter the BIOS Setup screen on your first try, repeat the following steps until you are successful.
To open the BIOS Setup screen:
1. Turn off the PC and wait about 5 seconds.
2. Turn on the PC.
3. When the first screen appears, press the F1 key on the keyboard. (You can press the key more than once.) The BIOS Setup Utility Main menu appears.
NOTE: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
4. Use the keyboard to navigate through the menus.
You may need to remove the battery and then back in.
Jul 21, 2009 | Computers & Internet
How to disable cahing or shadowing
You can do this in your BIOS settings. When you reboot the computer, look for a message that states what key on the keyboard to press to enter BIOS settings. Usually DELETE key, F1 or F2 key. Look for advance settings tab in BIOS menu. You will see it under there.
Mar 28, 2009 | Microsoft Windows XP Professional With...
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Blue screen when starting up
just double check the keyboard connection if it's ps2 type connector; if it's a usb mouse it won't work cos the drivers have not loaded. Only other solution is to remove right side panel of pc and locate the JBAT1 terminal and move jumper from pins 1-2 to pins 2-3 for a few seconds and back again. Turn on pc and then hopefully you can access the bios to set the time and date and save settings then re start.
Jan 20, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
HP Pavilion Elite M9060N PC Desktop Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
