Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Lg - LDS5811ST Dishwasher OE Error Code
OE error -
no blockage in drain hose.
disassembled sprayer and drain assy -
no blockages..
pump motor?
erau2008@gmail.com
  • 1 more comment
  • Doc White Jun 15, 2008
    Added a new garbage disposal. Dishwasher did not drain on next use. Panel shows OE error.
  • Bob1348 Feb 28, 2009
    I have an LG LDS5811ST Dishwasher, it is 3 years old, when I turn it on now after 2 minutes of hearing the humming sound (normally did that at the beginning) an OE error code appears, I checked the drain line and it is clear can get water through without any problems. is it the the pump or electronics?
    does anyone have a LG LDS5811ST Dishwasher with EO error Code?
  • 3,230 Answers
Hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Posted on May 06, 2009
    Champion:
  • 210 Answers
In older units prior to mar 07 LG has had a problem with wires getting stuck in the insulation and breaking. Remove door panel and check for broken wires. (turn off power) Check for continuity splice and put insulation in between. This is most likely the problem.
Sgt 48
Posted on Jun 07, 2008
    New Friend:
Remove right side cover. There is a clear trap for the drain. Unscrew vent inside dishwasher to remove. Cleaned out food which was blocking one-way valve. Problem solved!
Posted on Aug 17, 2013
What do i do to fix error code OE on my LG dishwasher
Based on what it mentioned on the LG website it is an error indicating a drainage error. The solution might be to clean the drain filters at the base, check drain hose under kitchen sink and behind dishwasher for kinks or blockages. On make sure the kitchen sink drain is not blocked. Worst scenario is a clogged drain pump. you will have to provide the model number for any further analysis.
Sep 19, 2014 | LG Dishwashers
What is error code OE for my LDF 7561ST
The OE error code indicates a "Drain Error". Check the drain hose for kinks or blockage. Check also the drain outlet of the sump inside the dishwasher for blockages.
If the above is all well, disconnect the electrical supply to the machine, close the water supply. Now check the wiring firstly for security and condition then the resistance of the drain motor by removing the electrical plug supplying power to the motor.
Measuring between the "Live" and "Neutral" pins of the plug on the motor side, the motor coil should have a resistance reading on a multimeter of between 20 and 40 Ohms, if not, the motor will have to be replaced.
Jul 03, 2014 | LG LDF7561ST
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Getting a "oe" error how
See
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Check the drain hose for blockage. and see if the water filters is clogged. Specific instructions will vary based on your specific LG model. Most LG frontloaders have an access panel on the front for the water filter.
Apr 21, 2011 | LG Washing Machines
Have a LG dishwasher with a OE error. Took machine ouside and it works well with the garden tap hooked to it. Put it back inside and does not work. I noticed a major kink in the inlet hose, would this be...
LG themselves have some information on this error code..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG front load washer OE error. cleaned filter need
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Jan 02, 2010 | LG WM-2277HW Front Load Washer
Oe error...manual says clogged but cant find clog
It is important to start where the drain hose connects to the drain. Probably connects indirectly to the garbage disposal. Look for blockage there and work your way back to the dishwasher.
IF you can't find a blockage, then it is time to remove your lower spray arm and the approximately 9 screws that secure the filter assembly to the sump floor. Rinse everything that you remove.
Using a flashlight, inspect the entire sump area for debris (watch out for broken glass!) Look closely where the drain pump is located. You will probably find some sort of blockage jamming that pump.
Reassemble and test. It is rare, but an OE error could be created by a failing drain pump motor. But try everything else first.
Good Luck!
Apr 21, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
3,079 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
