Question about Zebra P330i Thermal Card Printer
My zebra card p330 dont recognize the colour ribbon, only detect the mono riboon
  • 20 Answers
Please make sure you are using a genuine ribbon that is compatible for your printer model, a color ribbon would be 800015-440 or a higher yield 800015-540. Make sure the ribbons are under 2 years old and are not replica ribbons.
Please check your ribbon and make sure the white adhesive label on the side of the ribbon spool is not damaged.
In some cases incorrect driver installation will also cause the ribbon to be unrecognized by the system. You can reinstall the printer driver.
The last and least common scenario is that the printers ribbon detection module needs to be replaced.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
    Champion:
  • Zebra Expert
  • 285 Answers
Try to send the command !SA from the driver. And run the Ribbon calibration
Posted on Nov 13, 2010
Can i use Zebra i-series YMCKO ribbon in Javelin i-series printer
hi, not sure, but they have diferent ribbons, 800000-440 or -415 ....
try difirent ones
May 13, 2014 | Zebra P330i Thermal Card Printer
P330i gives out of ribbon error. When completing command "!SA" it ran the blank card through the printer into the other side. After right after that the printer flashed the "out of...
The printer uses three sensors in relation to the ribbon. The RFID (chip on ribbon). When you go into the printing preferences for the printer it should detect any color ribbon, and say ribbon type changed to (ribbon type). If so both the ribbon and RFID sensor are working properly. Then there is the color ribbon sensor, which has the blue and amber LED's, and is used to detect the panel of the ribbon. Thirdly the flag sensor which is on the back end of the supply reel, to detect the ribbon turning. . Additionally, CALIB command has never worked for me. !SA is an auto self adjustment for multiple sensors. additional you can use !CSA 0 without ribbon in machine, then run !CSA 1 with a ribbon (color ribbon is a must with any calibrations). You can also run !SAP 0 for card sensors !SAP3 for mag encoder card sensor. !SAP 1 for ribbon calibrations. if all else fails, you can manually set the ribbon by using !CSA 5 70 120. Please remember these commands are for genuine zebra I Series printers, and that they are case sensitive, and spaces are present. If none of the above corrects the issue you may need to replace one of the three sensors, the daughter board, or possibly the main logic board.
Sep 20, 2011 | Zebra P330i Thermal Card Printer
Printer doesn't recognise the color ribbon and print only in mono.
Try !SA command to calibrate ribon and printer, send command from the driver
Oct 07, 2010 | Zebra P330i Thermal Card Printer
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
Sep 25, 2010 | Zebra P330i Thermal Card Printer
How do one resolve and out of ribbon error, when there is a a ribbon present. I'm getting this error on a P430i zebra printer.
The P430 and the P330 are similar, P430 print both sides from the card, and the P330 just print one site, but the commands to send are the sane. Please try !SA command from the driver.
Sep 22, 2010 | Zebra P330i Thermal Card Printer
Command error on Zebra p330i
some commands don't work on some printers, depend the firmware and the printer P110 or p330, what commands you sending?
Sep 03, 2010 | Zebra P330i Thermal Card Printer
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
Zebra P330 not printing in colour
try to set properties of printer from grayscale only to another
May 04, 2009 | Zebra P330i Thermal Card Printer
OVERLAPING OF COLOURS.
go to zebra and download the latest firmware and drivers (free).
update the firmware first
turn printer off
then uninstall (from uninstall programs) the zebra drivers.
then install latest zebra driver.
turn printer on
Double click on printer icon, click on properties.
Click on the device options tag, then click on the properties next to tools
Enter "CALB" and click execute - this will re-calibrate your ribbon
First try the CALB, if your current firmware does not recognize it, then you will
need to upgrade the firmware as above.
Oct 30, 2008 | Zebra P330i Thermal Card Printer
Zebra P330i Thermal Card Printer Logo
551 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
