Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
My Life Fitness treadmill needs to have the motor control board replaced. A new one is costly, where would I get a used one? We are in Ontario Canada.
  • 79 Answers
If it is a classical model 9500/9500HR/9100/9100HR can take the card to a qualified technician mail, you must open the controller and change the following components: D4015L (2) 2N6507 (2) TIP110 (1) and in the latter case there to change the IRGBC40S.
if you treadmill is the Next Generation you should buy new and can find on sportsmith.com
Posted on Sep 11, 2010
I have a life fitness treadmill t95 will run sometimes but a lot of the times I am getting workout initialization timeout replaced motor control board with a new one swap console whit no luck
If you have replaced the console and the motor control board, then I would think that the issue would have to be with an intermittent connection or short in the wiring harness. That is really the only other component that you haven't mentioned. I assume you have verified power from the outlet. For more support, please use the following link. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
May 07, 2018 | Life Fitness Exercise & Fitness
Life Fitness 9500HR Console Reads Motor Command Error and the Red Led #1 is not flashing.
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
May 30, 2014 | Life Fitness 9100 Next Generation...
Our machine display show the following masage MOTOR CONTROLLER COMM DRD
two possible issues
one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
contact glide for their non clogging wax to resolve this issue
good luck
Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
One of our Life Fitness 95 Ti treadmills had smoke coming out of the front and after cutting the power and letting it cool, upon plugging it back in, the Motor Control Command Bad prompt came up. Any help...
remove the motor control box from under the hood, there is the motor control board (mcb) and capacitors inside the box remove the mcb and check for damage and /or burnt electrical smell also inspect condition of capacitors (4 round cylinders)
if this is the cause you need to get the board repaired
contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping details i have had many repaired by them .the cost is $200 which is a deal considering a new one is $1000
the most common reason for mcb's burn up is a resistor blows due to overload caused by too much friction between the belt and deck board ,and that could be the result if you have an auto waxer nozzle that is plugged up . these nozzle should be cleaned out once a month
note that glide has a non clogging wax to eliminate this issue you ask them about this as well
if you have to send out for repair , make sure you remove the wax board and small electrical component on outside of box and keep them in a safe place as you will need to reinstall them on the new box good luck
Dec 17, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Allready in the start up screen module comm error what is that
two possible issues
one unplug treadmill remove hood and make sure the main power cable to the motor controller box is in tight power back up and see if that worked
two you might have blown your overload resistor on the motor control board (mcb) . unplug treadmill and remove the motor control box . remove the motor control board out from inside the box and inspect it for damage and/on electrical burn smell. if you find damage you have to get it repaired. contact glide fitness products in santa ana california 1 866 637 4600 to get all information including shipping. it cost $200 plus shipping which is a deal considering a new one is $1000 . if you do send it in for repair remove the wax board and electrical componeton the outside of the box and put in a safe place as you will need to reinstall them on the new box the most common cause for the overload to blow is friction between the belt and the deck board ,if you have an auto waxer the nozzle is usually plugged clean the nozzle once a month . contact glide regarding non clogging wax if this is best for you
good luck
Dec 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
I have a life fitnes treadmil. The read out says
u would have 2 buy a new motor controller communication board and replace the old 1 its very difficult
Jan 23, 2010 | Life Fitness 9100 Next Generation...
9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Apr 22, 2009 | Life Fitness 9100 Next Generation...
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
806 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
