Question about Watts Onan Portable Generator - 4000 , Model# 5500
Toro generator T1800 - Watts Onan Portable Generator - 4000 , Model# 5500
Will rain damage lawn tractor T1800 ?
No it will not, but still best to cover it with a tarp.
Aug 22, 2017 | Garden
My FR691v-as07-R toro timecutter's battery discharges while running. Replaced the Battery, voltage Reg and Diode, still discharges.
It sounds like a job for a volt/ohm meter.
I am not familiar with the model but the basic principles are fairly consistent.
Either there is something causing the battery to discharge at a greater rate than the generator can recharge it or more likely the generator simply isn't working or isn't working efficiently.
In order to charge a battery the generator must provide a higher voltage than the battery or current will not flow. Assuming a 12 volt system the voltage of a fully charged and healthy battery is 13.2 volts. The generator must provide a higher voltage and typically would be around 14.5 volts for solid-state or electronic systems and 15.5 volts for electro-mechanical systems.
Scale the voltages up or down for 6 volt or 18 volt or 24 volt systems...
Isolate the battery from any battery-supplied accessories and then with the engine running fairly fast check the voltage across the battery. If only the battery voltage is present it indicates a generator problem.
As well as providing a higher-than-battery voltage the generator and all the associated wiring and connectors must be able to provide the current flow. In the case of problems it is best to go back to basics and carry out a visual check of all the wiring and connections and check the continuity and insulation of the generator windings and wiring, rectifier diodes, brush gear if there is any fitted and earth connections if it is an earth return type system. It is a good idea to use a wiring diagram for reference.
If the generator is a permanent magnet type there have been rare occurrences where a generator has become inefficient due to a loss of magnetism. I repeat this is a rare occurrence and the fault probably lies elsewhere and a systematic approach and reference to a wiring diagram will usually isolate the fault.
Jan 14, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Samsung product registration
GOTO http://www.samsung.com/us/support/register/product to register a product. For another country pick from home page
Jul 28, 2014 | Samsung Galaxy Tab 101 Tablet...
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Toro 42" Kohler engine back fires once after use/shut down. filters, plug are new
Backfire is normal if the fuel mixture is too lean, check the color of the plugs, they should be biscuit brown / tan. If they are grey, it is too lean and can cause valve over heating. Also the timing maybe off
Aug 30, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Generator parts
you neer said what part you want and with it fits to.
generator and filter?
and suzuki sells them. is this a car? or a Power generator , this is a car forum.
Jul 15, 2013 | Suzuki Cars & Trucks
My toro lawn mower is hard to start in cold weather. (40 to 50 degrees), I have an auto-choke. mower was bought in spring of 2010.
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Nov 01, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
564 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
