Question about Dryers
My Creda Excel T323vw dryer is only blowing cold air ?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Is Creda tumble dryer model T323VW, Serial No 801280178 at risk of fire as reported in the news?
Sorry we do not have any information to that affect here. Please contact the manufacturer.
Feb 22, 2017 | Dryers
How do i fix a tumble dryer blowing cold air
When you have to put this question here, I don't think it is wise to try to repair it yourself. It can be caused by lots of different things, Like a defective heater, a lose connection or a defect thermostat. When your dryer does not have an overheating security switch that came out and you can't reset it, a skilled technician should see into the dryer. It works with voltages, to dangerous to work with, when you don't know what you are doing. Please be careful.
Jan 30, 2015 | Indesit Ariston Creda Hotpoint Tumble...
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
Can my creda excel 1200 be converted to fill with hot water instead of cold water
Unfortunately it will need cold water for the rinses. Also it controls the temperature of the (hot) water itself which it would not be able to do if fed with water that was too hot- for delicates for instance ;-0(
To use your hot water would require a hot AND cold fill washer, sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Creda Washing Machines
Creda compact 3 37301 tumble dryer pull down door. Not heating only rarely, have changed the element. It heated a little while but starts blowing cold air. Drum is working and fax at back
I would suspect thermal fuse, easiest way to test is to tape wires together and start dryer. Safety note if left like this it will start a fire. It is located on the back of the dryer and has two wires connected to it. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Usually, failure of a thermal switch is caused by extreme heat: meaning that the dryer is not venting properly, clean dryer of lint inside and outside as well as the vent tube. Good Luck Tim
Dec 16, 2010 | Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Creda condenser dryer
remove the back plate and check the heater and stats. probaby the stat open circuit
Jul 11, 2008 | Dryers
Creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Jun 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
164 people viewed this question
Top Dryers Experts
