Question about New World 70TC Electric Single Oven
How do i get the clock and timer sorted on my cooker, i don't have a instruction book and the alarm keeps going off!!!!!! help me please
Stoves 720G Manual
SOMEONE POSTED
However...I discovered the little buttons on the timer come out completely. So I used a cocktail stick to poke about inside the holes where the buttons go till the Auto mode light disappeared and the cooker went back to manual. And my oven works again as before.
Jan 04, 2015 | Stoves Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    I didnt get a user manual with my creda cooker dont know how to set the timer
    try this site for your manual
    kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
    hope this helps
    Apr 28, 2010 | Ovens
    Cooker clock requires resetting
    You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
    The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
    Hope this helps.
    Jan 06, 2010 | Ovens
    Lost handbook for cooker. Cant remember which
    There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
    TO SET THE TIME OF DAY
    Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
    TO SELECT AN ALARM TONE.
    Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
    Releasing the button after the tone has sounded will automatically set that tone.
    SETTING THE MINUTE MINDER.
    Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
    You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
    After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
    If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
    Dec 13, 2009 | Stoves 720EF Electric Double Oven
    Creda Solar Plus Model 48339N Clock/Timer not working
    You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
    The top then slides towards the rear, then you can gain access to the timer unit.
    Hope this helps.
    Dec 08, 2009 | Creda Ovens
    Timers on my aeg competence cooker
    Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
    Aug 10, 2009 | AEG B1180-4 Electric Single Oven
    Faulty timer function on Stoves 720 EF
    To take off the front button panel.
    First power off the cooker, then remove the three right control knobs - they are just push on and push off. There are flats on the spindles matching contours on the knobs to ensure thay go back correctly.
    Lower the top oven/grill front. Under the front button panel there are three screws going upwards. One at each end and one in the middle. Remembering how they are installed, remove them. The panel will now be loose but it is held in postion by two or three lugs which are along the top inside edge of the panel. They, from what I remember, hook into the inner panels of the cooker. I think you have to lift the lower edge of the panel towards you, to overcome the upward bend of the lugs.
    The buttons for the clock are purely push fit and if you want they can be removed using a thin bladed knife.
    I have to say that if you want complete access to the clock, I think you will have to take out the complete oven from the unit and take the top off, so be warned. Instructions of how the cooker is mounted are in the instruction manual.
    Putting the front panel back I found to be fiddily - ensuring the lugs are located correctly, especially the one by the clock doesn't always want to work. In the end I left that one not positioned correctly, so in effect the front panel is slightly out at the left hand end.
    Best of luck!
    Jan 28, 2009 | Stoves 720EF Electric Double Oven
    Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
    get manual here
    http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
    good for 60 days only
    Nov 09, 2008 | Belling Ovens
    Zanussi Built-In Oven Clock keeps resetting?
    The 1000uF/10V condensator in the timer unit has to be replaced.
    Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
    New World 70TC Electric Single Oven Logo
    41 people viewed this question
    Top New World Ovens Experts
    paulcarew
    ashburton
    Are you a New World Oven Expert? Answer questions, earn points and help others
