Question about Zenith XBV442 DVD Player/VCR
Error symbol keeps flashing in display window, and It won't go off?
  • thomasd164 Sep 04, 2010
    I'm not sure what a disc or triangle symbols are. The set is five years old and has been working very well. I have a tape I was reviewing in the vcr and turned it off. then the word "ERR" appeared in the display window. ( thats the window that show when the tape is rewinding , etc..I tried ejecting the tape and the word eject would show for a second or two, than "ERR" comes back into view. When I have the TV on and have it set to channel 3, (which is channel it must be on for vcr or dvd to work), and then hit the power button on VCR the channel It is set to will appear for a second or two and then the "ERR" reappears. I am completely confused. I appreciate any help.
    Thanks
  • Zenith Master
  • 17,130 Answers
Check the power supply , the regulators for the correct supply voltage marked to the main board.
If Ok then it is possible there is a fault in the Main board, possible in the RF processor/decorder.
Might need the full replacement of the board as the set is not showing any signs of shifting the error message.
Make sure that all the connectors are plugged in well, remove and reconnect.
Tap to see if there is any change, if so then a possible dry sodering joint is present. Do a touch up job to solder and check.
Posted on Sep 05, 2010
  • 10,515 Answers
Kindly provide more details - Is it a disc error symbol or a triangle ?? few more details would really help us.
How old is the unit? Is the unit working even for few seconds / minutes or not?
Thanks!!
Posted on Sep 04, 2010
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Phone keep flashing screen on and off and won't stay on
I've had the same problem. Best solution is to put it on charge, face down for a few days. For some reason, overheating the phone by charging it for too long helps. My has this problem, that solves it but it'll come back again....
Sep 18, 2012 | HTC Radar 4G Windows 7.5 Smartphone...
I have a Mitsubishi magna 2001 model and I'm having computer problems the battery symbol keeps flashing and it keep stalling and won't idall properly
You need to have the Alternator tested, the battery symbol indicates the system voltage is low. The other problems are due to the low voltage.
Sep 18, 2012 | 2005 Mitsubishi Magna Wagon
THe machine won't rinse. Displaying a "OE" symbol
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 26, 2011 | LG Washing Machines
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Getting a red ''wrench'' symbol, spits out blank page when making copy, error message to turn off/on main switch which we have done, but doesn't clear the error. The red ''wrench'' symbol keeps coming...
Press "clear/stop" and "8" at the same time. An error code will be displayed as long as these two buttons are held down. What is the error code? Let me know, please.
Sep 01, 2009 | Lanier Office Equipment & Supplies
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Zenith XBV442 DVD Player/VCR Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
