Question about Thermador CIT302DS 31 in. Electric Cooktop
Our CIT302DS Thermador Hybrid cooktop has F-2 is flashing for one electric burner. New PC board installed after F-4 was flashing. I have turned off the power to try and reset and left off for more than an hour. Factory "trained" technician can't figure it out. The burner with F-2 will not come on but the rest will.
  • 213 Answers
SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Posted on Nov 30, 2007
mikedurland
  • 481 Answers
SOURCE: Electric coils for old Thermador cooktop Model #TMH45
i just checked repairclinic.com and they seem to have a lot of parts for Thermador. you just need your model number. if the burners look anything like this, then you might be able to buy aftermarket burners a lot cheaper at lowes or home depot. thermadore parts are very expensive.38e8186.jpg
Posted on Jul 20, 2008
textonor
  • 130 Answers
SOURCE: Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Posted on Aug 09, 2008
SOURCE: Need to convert a Thermador cooktop from Natural to LP
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1048620&PPStack=1
try this link.
do not drill out the jets they will not work properly.
I would check all your documentation you may have the convention kit with your owners manual or it may be attached to the oven.
Posted on Nov 15, 2008
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Posted on Jan 25, 2009
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
Have a thermador pc366 six burner range, the 2
Did you get an answer on this? Have the same problem and the house call starts at about $100
Sep 21, 2009 | Thermador PC366BS Stainless Steel Gas...
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Jul 20, 2008 | Cooktops
Nov 29, 2007 | Cooktops
Won't shut off!!
there is a control board under the glass where you touch to make it come on. some models were recalled. it you contact thermador they should come and take care of it for you
Nov 25, 2007 | Thermador 37 in. CET365 Electric Cooktop
Thermador SGCS456R 36' gas cooktop
Take apart the cooktop and it is the potentior on the valve for the simmer burner that is usually the issue.
Aug 15, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador CIT302DS 31 in. Electric Cooktop Logo
120 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
