Question about Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor
Scneen won't light up - Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor
  • 11,361 Answers
Check the fuse, transistors, cold solder joints.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 05, 2010
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
Pentair pool light fiber optic won't light:
check light generator on deck light probably burned out
Jun 14, 2011 | Pentair Pool & Spa
I have a laptop inspioron85 and win laptop booth up than the scneen go black
you're problem could be quite a few things:
1. your screen may go dim because is failing or your bios may need to be upgraded.
2. you may have a video-card/driver problem that may be corrected with an update. connect a monitor to your laptop and with the key board combinatin sent the output to the external monitor if it works your video card is acting up.
3. tried to boot in safe mode.. if it works.. it's possible that is a video driver problem so go online, get the latest driver from the manufacturer of your laptop and update as per their directions.
post your findings and more details if you need follow up
Nov 26, 2008 | Microsoft Windows XP Home Edition
Dell UltraSharp E153FPb 15" LCD Flat Panel Monitor Logo
212 people viewed this question
Alun Cox
