Question about Hyundai ImageQuest L17T 17" LCD Monitor
MONITOR BLICKS AND NOTHING COMES ON THE SCREEN
My promblem is that when i swich the power button on the monitor blicks
for a long time befor stopping.
And after stopping nothing appears on the screen.
I would be very grateful if you could help me solve this problem.
Thanks for your concern.
T.Chandiku
  • 981 Answers
Grateful how? Neverminding that detail, perhaps your screen's backlight or the power supply for it has failed. There's nothing to do but compare your unit's operation with that in the Service Manual or that of an operating unit; this is complicated by the fact that components might send an OK signal back to the main controller, so removing the bad parts will not necessarily mean the unit behaves normally otherwise. It may be as simple as rinsing the cat barf out with water and D.I. water (but you would still have to open the thing up on towels to find out.)
Of course the main power supply might also be faltering. you can probe the supply (with a DVM or scope) to see how steady that is.
Posted on May 11, 2008
How do i get the computer to come out of power save
1. Swiched CPU power off (But Monitor on - though blank )
2. Removed motherboard battery(its like a watch battery but quite bigger)
3. Then Swiched th CPU on
4. On screen message ( the I pressed F1 on the keyboard) .
now see what happen.
Aug 15, 2012 | HP Computers & Internet
My tower is plugged in and the monitor is plugged in but my windows will not show up on my monitor. It says to hit a key to get out of power save but wont do anything
My moniter has a black screen and is blicking blue light. i have a proview model 2200w? Was working fine until i shut down yesterday. I unpluged, nothing happened. Could it be in a sleep mode? If so, how...
this is so common in lcd monitors, its the power suply board.... most likely a capacitor.. so type a model# into google following the words "power suply" it will probably be close to $50-$60... thats better than buying a new one
hope this helps you
Feb 06, 2011 | Proview PL576Ws 15.4" Widescreen LCD...
Does nothing when i turn it on............i can hear fan running. but screen is blank. I have a compaq presario f500 with windows vista on it.
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 27, 2011 | Compaq Computers & Internet
Fujitsu lifebook screen will not come on
Could be a dead screen, use your vga, hdmi or svideo port to an external monitor or tv, if you get video there, then your laptop is still working and it is your screen. Check to see if you see any pictures on your screen but it would show in really really dark picture... if that is the case it is your screen backlit bulb that gone bad and the screen will need to be replaced. If nothing appears on your screen but you get picture to a external monitor via s-video, hdmi or the vga port then it could be that you have a loose cable connection or bad wireing somewhere between your latop base and the screen. If nothing at all appears on your screen or the external monitor source then you have a promblem with your laptop.... and those promblem can be in a wide range of trying to seek out the defective part.
Jan 14, 2011 | Fujitsu LifeBook S6520 Notebook
Blue light flashed on the power swich
Check this site regarding monitors and capacitors. This is very likely a capacitor failure.
Apr 19, 2010 | Computers & Internet
Green light blinks but TV will not come on...nothing
Could be the lamp has gone out. If this is a DLP the lamps are pretty easy to change and cost $130 to $200 dollars. Check the lamp before you toss it out.
Sep 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen goes black
Could be a loose cable connection the cable that runs between the LCD and the laptop my come loose from time to time and the screen will go black you have to be carful with this because you may be shorting out the inverter and eventuly you will have no picture it should be and eas fix if the cable is loose Go to the manue or service guide and find out how to open the Lcd cover behind the Lcd sceen there should be a connector make sure it is properly connected
Mar 24, 2009 | Compaq Computers & Internet
Dell Minitors has lost power
small cable to button/control lights may be disconnected
Sep 18, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Hyundai ImageQuest L17T 17" LCD Monitor Logo
275 people viewed this question
Top Hyundai Computers & Internet Experts
Tom Stevenson
Level 1 Expert
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
