Question about Nokia 6230
N keypad sound, enhancement logo showing
My nokia handset has no sound when hitting the keys, the headset logo is on the front screen which means an enhancement is attached but there isnt!
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
Posted on May 28, 2008
Getting bored from Nokia C5-03 touch screen Hang problems & display related problems
Hi @Jayeshsinh DO this steps:
>Check your phone, that is it on.
>Hold and press Green handset + Red handset + Camera key.
>Release holded keys, when you see Nokia logo.
>Now tap your lock code. (The default lock code is 12345).
After this operations your phone will reset and maybe restart.
OR
>Press Power button, until your phone turns on.
After that press Menu button and goto Settings -> Phone -> >Phone management -> Factory Settings -> Delete data and restore.
>Confirm your decision -> press Yes.
>Done
Oct 29, 2017 | Nokia C503 Cell Phone
When i turn on my N95 mobile,it just shows nokia logo with white screen and it doesn't get off also.
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 06, 2011 | Nokia N95 Cellular Phone
How to set any key answer for nokia 1600 handset
go to enhancement settings, select headset, there you find anykey answer option. i believe there is no anykey answer for 1600, there is option for automatic answer. the path is the same as i said above.
May 10, 2010 | Nokia Cell Phones
No sound in handset mode but working fine on loudspeaker
YOu know,its all right with ur phone,but the headset may not be supported by the phone,i mean its enhancement cant support the headset model. change it and it might work.
Jun 10, 2009 | Nokia 3120 Cellular Phone
ENHANCEMENT ICON
connect your headset and remove it or twitch off and remove it
Sep 28, 2008 | Nokia N70 Cellular Phone
Nokia 6020 won't start up
Unfortunatly check info service usually means your phone is moisture damaged.Especially if the screen goes blank.Check if the charger unit has turned slightly green and mouldy looking.Take off the back cover and check the battery does not look warped and also remove the front fascia and check for signs of staining on the keypad.It is not a screen problem if the logos are still appearing .it is an internal problem.If your phone is moisture damaged there is no way of repairing it.Bring it to a mobile repair shop to get it opened up and examined.hope this helps
Sep 26, 2008 | Nokia Handsfree For 6020, 6101, 6102...
People can hea me but i can hea dm
check your phone settings then select enhancement settings.. if aint solve maybe the buzzer of the your phone is defective..
Sep 23, 2008 | Nokia N91 Cellular Phone
Phone enhancement
try reflashin the phone thaht may help
Jun 13, 2008 | Nokia 6233 Cellular Phone
Problem with keypads
my nokia 2100 at screen appreance "contact service" whats means?
Aug 16, 2007 | Nokia 2100 Cellular Phone
Nokia 6230 Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
