Question about HP DesignJet 5500PS InkJet Printer
Designjet 5500 spins up disk ok, load firmware ok, gets to next screen "Initializing IO" and gets stuck. Is this the Harddrive?
Check and replaced the i/o card or install to other slot
Posted on Sep 28, 2010
    Problem Solver:
  • 10 Answers
Turn off the plotter.
Remove all Cards if any from the EIO slots
JetDirect card is usually plugged in there.
Restart the plotter without the EIO cards installed.
If the plotter starts normally.
Shut down the plotter,
Install the JetDirect back into the plotter,
but into the other EIO slot from where you removed it.
Start the plotter, if the plotter starts normally,
then you have one bad slot.
If the plotter hangs on the same error.
Replace the JetDirect, or what ever EIO cards you have installed.
Posted on Mar 06, 2014
HP Designjet 130 not initializing...
If there a jetdirect network card trying removing it and restarting.
Nov 11, 2014 | HP HEWLETT PACKARD Designjet 130 printer...
I have a HP DesignJet 3500CP when I turn on the power during Initializing I get an Fatal Disk Error and then I press Continue then it finishes with Error 090014 00000001? Anyone have any ideas? It has...
Replace the hard disk on the printer. If this printer has been sitting for 2 years, you will probably have major ink system problems also. Ink may have dried out and clogged up the printheads.
Jul 05, 2014 | HP DesignJet 3500cp InkJet Printer
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Hp designjet 5500 calibration error 2605
update the firmware. seems like there is a problem with the current one.
Jun 01, 2010 | HP DesignJet 5500PS InkJet Printer
Printer runs the self test and then initializing and then stops at "initializing, please wait" and goes no further. has new firmware and good memory???
I have had this problem several times and it was always caused by bad inkcartridges. Try starting up the printer without all cartridges. When printer tells you to place the cartridges put them in and see if you get an error. The cartridge witch causes the error is the "bad guy".
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
Error code 04C300 001E0000
This is an IO error. If there is a Hard Disk installed, remove it - the printer will run fine without it. If that does not solve the problem, remove the JetDirect card and run the test print. If the test print works, replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Nov 19, 2009 | HP DesignJet 1050c plus InkJet Printer
Initializing xd card
Put the camera into play or review mode then hit the ok/menu button on back and format the card. This will erase all of your photos so make sure you've backed them up or download them.
Jul 11, 2008 | Fuji FinePix 3800 Digital Camera
T.sonic 610 MP3. booting problem
that is ok as long as it does not get stuck on that screen - if it is getting stuck you may need a firmware upgrade from:
http://www.transcendusa.com/Support/DLCenter/index.asp
May 08, 2008 | Transcend T.sonic 610 MP3 Player
HP DesignJet 5500PS InkJet Printer Logo
685 people viewed this question
Seeker5211
Seeker5211
