Question about Kitchen Ranges
THe compressor fan on the Freezer side is making noise. The noise stops when the door is opened -- you can here the fan slowing and stopping when the door is opened. What needs to be done to stop this racket? Do I need to call a serviceman or is it a DIY?
  • j_scharf Sep 04, 2010
    No ice build up on top or back wall of freezer -- so I guess it's just the fan going bad. It's at the top back of the freezer compartment -- right behind the light lens. Correct?
    Quick and good solution. Thanks!
  • 4,059 Answers
The evaporator fan in the freezer stops when you open the door. Hold the button in which controls the light then it will continue to run if the compressor is running. The noise could be ice build up on the evaporator coil which is hitting the fan or the fan could be going bad and need replaced. It's behind the rear cover inside the freezer. It's not to difficult to change out.
If it's ice build up then you have a defrost problem.
Posted on Sep 04, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
The unit is making a short cranking noise.
Sounds like the freezer fan motor to me.
Open the freezer door.
Push in and hold the light switch on the door and listen for the noise.
It will probably be at the back of the freezer where the fan motor is located.
Could be a motor going bad or a ice buldup around rge motor blades.
Jul 31, 2010 | Jenn-Air JSD2695KES Side by Side...
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
My Jenn Air French Door Professional Refrigerator makes a strange annoying knocking sound. It seems to come and go and happens for a few seconds to close to 1 minute. It will stop soon after I open the...
You have two fans and a compressor which could be making the noise. Inside the freezer behind the back cover is the evaporator fan. It probably stops running when you open the door. Hold the door switch down to keep the fan running to see if it's making the noise.
the compressor and other fan is under the unit accessed from the back behind the cardboard cover.
Nov 30, 2009 | Jenn-Air JFC2089HE French Door...
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE Model # GSS20IEMBWW Refrigerator is making a vibrating sound in the back that stops when I open either door, but as soon as the door is closed, the noise starts back. Also, there is a lot of frost in my...
the inside fan that blows air from freezer to fridge side located on back wall either stuck has build up of ice or some debris is stopping or slowing it down open freezer door and look at back for fan remove cover and or frost covering hold door switch and look and listen to fan if labors or just hums remove and service or replace
Oct 14, 2009 | GE Refrigerators
Making noise and not cooling properly , when you open the door the noise comes to a stop like the fan slowing down
Your unit isn't defrosting. Your fan blade is hitting the frost that is built up in the back of your unit. All Samsung units are made when you open the door that the fan stops. You can check this but finding your door switch and see if the sound still continues. But you will need service and a part to fix this unit. Where are you located? We are the master tech company for Samsung in the Charlotte, NC area.
Aug 12, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
