Televison & Video Logo
Posted on May 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot adjust convergence on the blue. Its curved upward in the middle.Also showing a second image in blue.
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on May 12, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723426
Points
23750
Youre convergence ICs need to be replaced. What is the model number of your set and I will be able to help you out with the problem
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
1helpful
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
DOBLE IMAGE
THE CONVERGENCE DRIVER CHIPS NEED REPLACED. CHECKSUPPLY SAFETY RES ARE OK AFTER REPLACEING STKs RESET CONVERGENCE. CHANCE BOTH STKs.
Cannot adjust convergence on the blue. Its curved upward in the middle.Also showing a second image in blue. have manaully tried to adjust blue convergence over the cross hair, able to moves side to side...
whats the model number and i will post the ICs you need and post a link where you can get them with free step by step instructions with pictures so you can do the repair yourself and the ICs arent exspensive. Please reply to this same post.
Distorted image and color
sounds like the convergence ICs have failed. Will the red and blue move in all 4 directions when you try to adjust the convergence? If not the convergence ICs are bad replace both of them also check the resistors that power the ICs as they may be open as well.
1helpful
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
