Question about AEG 24 in. Favorit 86050Vi Built-in Dishwasher
The dw is blocked with the three led of delay start blinking in sequence. I think that i have to reset the dw, but i lost the manual. Please, could you suggest me in which way i can solve my problem? Thank you!
    Sergeant:
    Champion:
  • 323 Answers
Hold the start button for about 3 seconds and the blinking led will stop that should help
Posted on Sep 04, 2010
  • Roberto Gambardella Sep 06, 2010
    My dw hasn't the start botton but only the on/off switch. It starts automatically when the door is closed!! I tried to hold for some seconds all the bottons and I also tried all the combinations of 2 bottons contemporarly without results. When I hold 2 bottons contemporarly, the blinking led stop, but when I release the bottons they start again!!
Cancel light blinks maytag dishwasher
Check door switch. Also, the control pad may be shorted from water getting in between the plastic and corroding the connections to the buttons. DW
Apr 11, 2014 | Maytag Dishwashers
I have a Bosch ksu 44 fridge/freezer which has stopped working - just a click,click,click from the back and the control board led's flash with each click (1.5second intervals) - is it the control...
Very common problem on that fridge and a easy fix: Replace the two big capacitors on the right side of the control PCB 1uF = 0,68uF 250V They lost their capacity causing bad uC supply and this strange LED blinking. Be aware that this blinking can be intermittent and the fridge appears to return to operation. But the uC suffer a lot of internal resets causing intermittent operation stops, low temperature and more not easy recognizable or strange mal functions. So, if You face that blinking normally the capacitors are gone. Some strange and intermittent behaviors of the fridge are also back routed to this PCB - Capacitor malfunction. So enjoy this 30min fix. The capacitors should not exceed US$2 in Your local electronic shop. If You don't want to spend the US$2 You can find the capacitors as a lucky guy in a old PC power supply.
For other more complex problems be aware that the controller board has a very nice and helpful self test option. You go in this mode holding the temperature select button of the refrigerator (not the freezer button) then switch the fridge on and stay on holding the temp button for more 10s. The self test sequence starts in the moment when You release the temp button.
LED 1: Checking sensors (Blinking=OK - Continues=NOK, something wrong)
LED 2: The Flap opens and close two times (Alarm LED shows the open and close position, so the led must go ON and OFF two times in accordance of the detected flap position from the internal reed contact. (So, no action on the Alarm LED no movement on the Flap or a defect Reed contact)
LED 3: Fan goes ON and OFF
LED 4: Drain Heater goes ON and OFF
LED 5: De- Dicer Heater goes ON and OFF
LED 6: Compressor goes ON and OFF
LED 7: End of test sequence - Initializing procedure of normal operation.
Every step takes 30s and the whole sequence take tree and a half minute. Be aware that the alarm LED is no malfunction indicator. It has only the indicator function for the sensors.
The fridge goes in the normal operation mode when he passed the sequence. No further actions necessary.
Be aware that every time when the fridge faced a total power lost he makes a short silent 30s check sequence. If he face a malfunction (Sensors or actuators) he doesn't start the compressor anyway to protect the fridge for further damage!!! So, this test sequence is a nice tool to check that the fridge is in the right conditions to start the working and even so to check the compressor function before maybe a unnecessary replacement .
With a second build in test option you can select and activate devices in the fridge. For this You hold the fast freeze button and switch the fridge on. After 10s release the button and you are in a manual test mode. With the temperature button select the component - Push the Fast freeze button to activate or deactivate. For example: Select LED6 (Compressor) with the temperature button, push the fast freeze button for ON and OFF. But I ask You to be careful on this test mode to avoid further damages. For example a blocked motor that You should release better by hand than blow up by a tricky fingertip. Enjoy this fix and feel free for Crtl C + Crtl V.
Jul 04, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Jan 22, 2011 | Heating & Cooling
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
I need instructions to turn off service light in 1995 850 volvo
Keep pen and paper ready, as you might have to write down error-codes as you want to do this.
Turn ignition OFF
open the lids of the diagnostic sockets situated in front of the enginecompartment (by the fillercap for the windshieldwasherfluid)
Put the socket with a short lead on in the hole marked "1" on module A
Turn ignition ON
press the pushbutton on the top for about 1 second and WAIT.
The LED will blink in a sequence that indicates if there is any problems that need to be solved.
The led will blink 1 to 5 times, have a pause, blink 1-5 times , have a pause and blink 1-5 times.
Write down the sequence as you count the blinking. eg: 1-3-1
When one sequence is finished, you press the pushbutton again, and read the next code.
Repeat this until you read the first code again.
If the first code reads 1-1-1, all is OK and you can proceed.
After this you can reset the servicelamp:
Leave the connector in socket 1 on modula A.
Turn ignition OFF
Turn ignition ON again
Press the pushbutton for 5 seconds. Be patient.
Release the pushbutton and wait about three seconds, then the LED starts to blink rapidly
press the pushbutton for 5 seconds again and release it.
Turn the ignition OFF
Remove the connector from the socket, replace the lids and put the connector back in its rest.
Turn on ignition and start engine, the service lamp should not be on.
Any error-codes? Refeer to a Volvo-dealer.
Jun 30, 2009 | 1995 Volvo 850
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Red blinking led
My 42" Philips LCD did the same red blinking sequence last night. All was seemingly fine after unplugging it for a bit. An online search, though, has me worried that this may be the start of (potentially fatal) power supply issues. Anyone have a clue what that sequence means?
I've got one week left on my 1yr waranty, so I'm a bit concerned! :(
Thanks!
Jan 15, 2008 | Philips 32PF7320A 32 in. LCD Television
Kitchenaid dw clean light still blinking/ machine won't run...
I tried the following sequence, as recommended on a similar blog and it worked!
Open door
Quickly press :
Hi Temp Scrub
Energy Saver Dri or Heat Dri
Hi Temp Scrub
Energy Saver Dri or Heat Dry
Close door
All lights should come on
then clear and revert to cycle.
Feb 28, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
AEG 24 in. Favorit 86050Vi Built-in Dishwasher Logo
326 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
