Question about Panasonic DMR-E85H DVD Recorder
My DMR-E85H was in storage for a while. now when i plug it in, nothing! Salvageable?
  • ladyice69 Sep 04, 2010
    Thanks, not the power cord, it is compatible with another Panasonic unit and powers it up just fine. So where do I find a tech to test the PSU?
  • 3,153 Answers
If you are comfortable with dismantling the unit then its always worth checking to see that spiders etc have not gotten in there and cloggd up any mechanism and giving it a clean out with compressed air like you would use to clean computers etc.
It is also worth checking the power supply area too to make sure that any fuses are OK and that the borads have not been corroded by something.
Its a good place to start and you have nothing to loose and everything to gain. and if you do find anything not quite right in there then the choice is to take it to a pro or replace it depending on what you find.
Posted on Sep 08, 2010
    Guru:
  • 374 Answers
Quick question, can you check to see if the cord is soldered to the unit or not??
The unit sounds like the power supply could be damaged in which case it would have to be opened and replaced (may be more expensive than obtaining a new one) but we can check the cord first to see if its damaged.
Posted on Sep 04, 2010
  • Robert Dahmen
    Robert Dahmen Sep 05, 2010
    what is your location so I can try and track one down close to where you are at?
  • Panasonic Master
  • 19,396 Answers
Hi.
If there is no power at all, then problem is either power cord or PSU inside the recorder. Check if the power plug is fused (eg. in UK), in that case replace fuse. If that does not work, then the unit must be disassembled, and the PSU must be tested by a technician.
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
Pan. dmr-e85h turned itself on, self-check
Open case and look for failed capacitors, which are cylindrical and will have a bulging top and a yellow/gold substance leaking out. If this is the problem, search for previous solutions that mention "solder capacitor C1260" for the DMR-E85. I had a similar 'no power' problem with my DMR-E55 and my son and I were able to fix it Sunday. Not hard to do and mine is working again!
Aug 05, 2009 | Panasonic DMR-E85H DVD Recorder
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
DMR-E85H Remote is malfunctioning
i can supply you with one if you are intrested?
Dec 02, 2008 | Panasonic DMR-E85H DVD Recorder
DMR-E85H works fine after replacing IC but ......
Quite many possibilities. Since you replaced the IC, I'd figure you have a little understanding of electronics and ESD procedures. You now need to troubleshoot the driver for the display. Do a little research with your DVM... make sure the display is getting V. Should the unit be a uP type system, you are probably looking at the uP display driver circuitry [all in one] being bad and no way around the replacement should you desire a display. Should the unit be slightly older, you may get lucky with finding a cap or transistor problem for the driver. Moreso trans than cap.
Wish it were here.. always easier to take a peak and find the problem when it is in front of me.
Oct 15, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR E85H Shuts down when playing DVD or dubbing
the ic chip fixed mine tried to contact panasonic to give them negative feed back .its imposable
Mar 08, 2008 | Panasonic DMR-E85H DVD Recorder
PANASONIC DMR E85H dont startup
I was playing dvd and it just stopped and message came on saying ( please wait) It still has dvd in and cannot get it to do anything
Feb 05, 2008 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
