Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
I've tried to reset the lamp timer and my tv still wont work. What else can i try?
  • Marty
    Marty Sep 04, 2010
    I have replaced the lamp awhile back and was working fine until yesterday when it just shut off, but the lamp light on the tv blinks once in awhile.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
Have you tried replacing the lamp? If not, I would start there. Also, after replacing the lamp, make sure that the lamp door gets put back on or it will not come on. There is a safety switch that won't allow the tv to come on when that door is off. If you have already replaced the lamp w/ a new one and you are getting the same problem, then the problem could either be on the lamp ballast, or power supply board. Some tests would have to be made by a tech to determine exactly where the problem is. It sure does sound like a bad lamp though.
Posted on Sep 04, 2010
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
How to reset lamp timer on a sony tv KF-42WE610?
It should be in the general settings menu under lamp replacement. It will ask you if you've replaced it already. Hit yes.
Jun 17, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
I have a Panisonic PT-52LCX15 I replaced the lamp and now I'm trying to reset the LCD meter, I have tried holding the vol button and the split button and the red lamp light still is on, maybe you could let...
The lamp light should NOT be RED.
The lamp light should be yellow for the lamp timer warning.
There are two ways of retting the lamp timer=
1) on the TV use the vol - button. push until vol goes to zero, then keep holding it down
on the REMOTE push the "split" button
the yellow light should go out indicating that the lamp timer has been reset
if this fails to work,
on the REMOTE, use the "PLAY" button, instead of "split".
you may have to try this a few times to get it to "take". you'll know when the YELLOW lamp light goes out.
However, a RED LAMP light means you lamp is not working or missing.
reseat your new lamp into the TV...and be certain the LAMP DOOR is securely CLOSED.
Apr 12, 2011 | Panasonic Televison & Video
I have an HL- t50756 and it turns off every 10 minutes
Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE
then punch in the numbers 182 then POWER in that order, wait when the TV starts up the Factory meneu will appear go to Options press, then look for Lamp Hrs. to see how many hours you have on your lamp TV lamps last appox 2 years average use. 4,000 hrs. Try this, above where you see the hours go to reset or something like that and press to reset blub timer to zero. Your blub might still be ok, but the timer says times up and tries to shut off the TV thinking the blub is bad. By reseting the blub timer to zero the TV will think it's a new lamp. Until it really goes then no picture at all or gets very dark. Try this trick it might solve your problem.
Good Luck!
Oct 12, 2010 | Samsung DLP HL-P5663W 56" TV
HD 61Z456. MY LAMP LIGHT IS BLINKING CONSTANTLY. THE LAMP DID NOT SHATTER. I PURCHASED A NEW LAMP ANYWAY, STILL NOT WORKING. WHAT OTHER ISSUE COULD THERE BE?
try resetting the lamp timer first if that does not work you might have a ballast issue here is the link with the reset timer guide
http://www.fixyourdlp.com/2007/04/06/how-do-i-reset-my-lamp-timer-counter-after-replacing-my-lamp/
Sep 16, 2010 | JVC AV-35790 35" TV
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
SAMSUNG 52'' PCN5425R TV WONT POWER ON
when the timer light is turn ON, tv is telling you that lamp will be going out soon, is basically a hour meter, it just reach the limit of hours that tv haves program of use for a lamp and that you can reseted by:
1.- taking the lamp out nad in again, that way tv will detect there is a new lamp. If not.
2.- folow the instructions: http://www.fixyourdlp.com/blog/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter/
Jun 25, 2009 | Televison & Video
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
