Question about Whirlpool AWOE8748 Front Load Washer
My Whirlpool AWOE 8748 washing machine was showing error message F13. I swithced it off via the plug but the door will not open. Tried to switch it on again but no lights come on why?
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 28, 2010
Errore f02 modello awoe 8104
open the bottom tray door on front panel 3 screws on bottom front.
clean out the trap
May 10, 2014 | Whirlpool Washing Machines
Whirlpool awoe 8548
The f13 is a door lock error. You will need to replace the door lock mechanism, could also be the wiring or connections for the lock itself so check that first. Cheap part and easy to replace.
Jul 08, 2013 | Washing Machines
Whirlpool AWOE 8748 has no power. Changed fuse and tried in a different socket. Still no power.
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
F13 and door not opening washing stuck ith cage .
Hi
F13 is a door lock error which means that the door lock is bad and should be replaced. To unlock the door you can leave it unplugged for around 10 minutes and the door will unlock. Hope this helps...please post back for further assistance.
Daniel
May 10, 2011 | Whirlpool AWOE8748 Front Load Washer
My mum's AWOE8748 shows F13 it is only just over 1 year old how can I fix it.
Hi. The F13 error code indicates a problem with the doorlock mechanism.
Whirlpool have identified issues with some models and door lock errors so it may be adviseable for you to contact whirlpool customer services.
The error can lead to the door jamming shut.
First of all open the door, if you can, and check that the lock latch on the door is level with the door lock hole on the front panel of the machine. Sometimes you can accidently lean on the door when putting in or taking out the washing sending the lever and hole out of alignment. You can put pressure on the door to align it either way if not level. If you need more help then repost.
What area are you in?
Jan 25, 2011 | Whirlpool AWOE8748 Front Load Washer
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
Whirlpool AWOE8748 Front Load Washer Logo
962 people viewed this question
Dan Webster
Dan Webster
Sal De
