Question about Frigidaire Heating & Cooling
During extremely hot days water drips from inside of air conditioner--it is 24000 BTU-- most water drips through outside as it is supposed to but some drips inside is it the pitch of air conditioner? -if it were tilted more or is this normal condensation--it's not a lot of water but it wets the rug under it--it's been installed through the wall
  • Frigidaire Master
  • 19,396 Answers
Hi.
This AC has a drain pump built in. The AC leaking water is not normal. Probably drain system efficiency is impaired from blockage at drain lines. As first thing call Frigidaire at the number on manual and report the problem.
Posted on Sep 04, 2010
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
My 8000 BTU LG window AC is dripping on the inside of my house
Check that the hole in the back is not plugged where the water should be running out...also make sure that it is tipped slightly back towards the outside...
heatman101
Jun 11, 2011 | LG Electronic Window Air Conditioner
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
I have a whirlpool 24500 btu air conditioner it
It sounds like the thermostat sensing bulb is not sensing indoor air temperature?
Jun 07, 2010 | Heating & Cooling
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
There is water inside the air conditioner
hi,
It is normal for window air conditioners to have a puddle inside them during operation, actually they are designed so the evaporator fan wicks up the excess water onto the hot evaporator coils, keeping the unit cool, if it bothers you some, you can possibly adjust the outside brackets so it slants downward some or if your mechanically inclined , drill a small hole so that the water can drip outside, use caution though if drilling, be extremy careful what your doing- and make sure your not going to hit anything on the inside, you can see through the side maybe, hope that helps
J
Jul 15, 2009 | Hampton Bay Heating & Cooling
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Size
Greetings jdreisbaugh,
The tonnage is usually found on the name plate on the condensing unit outside. 12000 btu = 1 ton, 24000 = 2 ton and so forth. In your case the unit is 36000 btu, therefore a 3 ton.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jul 24, 2008 | Intertherm P3RA-036K Air Conditioner
Water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Sep 22, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
85 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
