I need an electrical diagram for a Heil 9000 forced air furnace
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
  • 308 Answers
SOURCE: The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Posted on Jul 28, 2009
How would I know if my heil 9000 heat pump actually has indoor electric heat strips for the defrost mode?
Turn breaker off to outside unit and then turn heat on. Uf you have heat, you have electric heat strips
Dec 02, 2016 | Heating & Cooling
Heil ntc5125bkd1I furnace. Where can I get a wiring diagram?
There may be a wiring diagram pasted somewhere inside the housing or provided in the related document package.
Feb 10, 2016 | Heating & Cooling
I have a Heil furnace (Temp star 9000 I believe) model number NUGS075BG03 that is not working properly. The inducer motor runs fine and I can see a blue flame through the sight glass but the circulating...
you need to check to see if blower motor runs in ac mode, if not then the first thing you want to check is the capaciter for that motor. if capaciter is good, motor may be locked up, you can check the amps of the motor by putting an amp clamp around wires going to blower motor, all ratings should be listed on motor
Oct 17, 2013 | Carrier Icp Heil Tempstar Furnace Blower...
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Dec 30, 2010 | Water Heaters
Where do install a Heil furnace filter?
MAYBE IT DOES NEED IF THE FILTER IN THE COLD AIR RETURN GRILL MAKE SURE THEIR IS NO FILTER IN THIS FIRST , AS 2 FILTERS ARE NOT BETTER THAN ONE WHEN COME TO ELECTRIC FURN AND H/P ALSO IS THIS A UP-FLOW ,DOWN FLOW OR HORZ MEANING AIR #1 RTN IN BOTTOM DISCHARGE COMING OUT OF TOP OR#2 COLD AIR COMING IN TOP AND DISCHARGE OUT OF BOTTOM OR #3FURNACE LAYING SIDE-WAYS AIR COMING IN ONE END AND OUT OTHER THESE WOULD DETERMINE FILTER LOCATIONS
Nov 19, 2008 | Water Heaters
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
