I have a b52 prodigy fx and the left side just shows disk error won't read disk. I am using good name brand disc's
night71
  • 328 Answers
SOURCE: Hitachi BX37E error
You can try to clean the laser lens first with a q-tip and 99% alcohol. If that fails, you should take it in for repair because the laser lens mechanism may be out of line because of a bump. There may also be a dust build up inside that prevents the proper movement of the lens. This can be done at home too.
Posted on Nov 18, 2007
AlmostBob
  • 550 Answers
SOURCE: cant read disc
the laser lenses may be dirty, a commercially available cleaner may help, not a solution, just a suggestion I am not familiar with panasonic
Posted on Aug 21, 2008
  • 6 Answers
SOURCE: Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Posted on Dec 14, 2008
SOURCE: Error 08 / Disk Locked error
With help of Yamaha tech staff, I inserted a business card under disk "lid" in bottom left corner, slid card to right to release catch. With catch released, pushed disc in to insure in OK, closed lid cover, then slide card from lower right corner to left to re-catch. Read disc OK.
Posted on Jun 15, 2009
SOURCE: numark cd mix 2 is not reading disk on left side
First clean the laser lens
Posted on Jun 24, 2009
Can you pls tell me what error message # 2881 means?
Error message 2881 means that the camcorder can not read the disc. Check to make sure you have the correct disc type. Only DVD-R 4.7GB and DVD-Ram types will work. If you are using the correct disk type, then you can try this: Eject the disk and if it it empty just open the cd door. With the lens to the left and the door on the top. look into the device. You will see to the left side a metal platform that houses the dvd laser. take and push the platform all the way to the left. Sometimes the platform fails to retract, so once you do this it may clear the issue. . Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Hitachi DZ-MV550 DVD Camcorder
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
My nintendo wii says an error ocurred when i put a disc in
first the obvious if ur new to wii.... make sure the picture side of the disc is the on the right side when you insert it (facing outwards)
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message
    Playing Super Smash Bros. Brawl? Click here for specific help.
    If you are getting one of the above error messages:
  • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
  • Ensure that you are properly loading a Game Disc.
  • If your console is placed vertically, the disc label will face to the right.
  • If your console is placed horizontally, the disc label will face upwards
If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
Cleaning a Game Disc Fingerprints, smudges, and other foreign material can interfere with a game disc being properly read by the Wii console. Please use the information on this page to properly clean a dirty Game Disc.
Important Notes (please read first):
  • Use only: straight strokes when wiping the disc (do not use a circular motion).
  • Use only: a clean, soft, cotton cloth (do not use paper towels, facial tissue, etc.).
  • Use only: water (do not use soap or any other cleaning solution).
  • Do NOT use: solvents such as: benzine, window cleaner, paint thinner, anti-static aerosol spray or abrasive cleaners.
  • Do NOT use: machines designed to clean discs or remove scratches. These types of devices could damage the surface of the disc.
Properly cleaning a game disc:
  1. Dampen a portion of a clean, soft, cotton cloth, using only plain water.
  2. With the damp part of the cloth, use straight strokes and wipe the bottom of the disc (non-labeled side) from the inside rim to the outside rim.
  1. Using a dry part of the cloth, use straight strokes and wipe from the inside rim to the outside rim.
  2. After all of the water has been removed, let the disc sit for at least two minutes to completely dry before inserting it into the Wii console.
  3. Try to play the game to see if the problem has been resolved.
    • If the problem has been resolved, be sure to properly take care of your game discs by storing them in their plastic cases in order to help prevent your discs from becoming dirty or scratched. Storing games in cases other than the ones they came in, or storing them outside their cases, may damage the disc.
    • If the same problem continues, the cause is likely damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
    • If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.) Please call 1-800-255-3700 to discuss possible repair options.
If you are occasionally experiencing disc read errors, you may want to consider purchasing the Wii Lens Cleaner.
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk. If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. I like to use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) Don't exert more force than necessary; it's a flimsy disk, not a kitchen sink. If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
good luck...
thank you for using fixya's assistance
if u felt i ve spent my time to help you a very helpful rating is appreciated.
Aug 12, 2009 | Nintendo Video Game Consoles & Games
Connecting the kaoss pad 3 to my built in turn table mixer
Try connecting the main output to the input of the Kaoss and the output of the Kaoss to your amp. You will get more signal.
Aug 04, 2009 | Korg Mini Kp Kaoss Pad
Jun 12, 2009 | Audio Players & Recorders
Brand new Wii - Will not read any of the disks
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jan 01, 2009 | Nintendo Wii Console
"Wrong Disk" error
I would assume that you finalized the disk after you burned them. THat being the case try the disk on another DVD player. If that does not work try burning another disk. Its possible that its either a failed burn, a picky DVD player or plain defective disc. So the only option left is to isolate the probelm.
Oct 04, 2008 | Memorex (3202-5639) (50 Pack) (32025639)...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
1,203 people viewed this question
 Grubhead
Grubhead
