go to run type cmd press enter in dos type ipconfig /all press enter and check if u get the ip address check the DNS it should similar to default gateway OR u can use your DNS ip address which is provided by your ISP or if you dont know that just use 8.8.8.8 check the should you need more help contact me on http://computernetworksupportindubai.com/
make sure you can access the router configuration page
change you computer ip addess to match the ip address range of the router
ex if router is 192.168.1.1 set computer ip to 192.168.1.2 subnetmask 255.255.255.0
and set default gateway and dns server address to gataway address
geateway 192.168.1.1 dns server 192.168.1.1
try it most probably you need to make sure you have configured your adsl user name and password and other settings in you router since you have rested it
1. hard reset ur modem ( it will set to bridge by default) 2. connect ur modem to WAN port at netgear router 3. connect ur pc to LAN port at netgear router 4. by default ur pc ip should be 192.168.1.x 5. type at IE/firefox address bar
username = admin password = password
6. enter all basic info (ISP = other, streamyx username password, wifi setting) 7. set value for idle timeout (in minutes) = 0
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
