Question about Dishwashers
Servis easy logic dishwasher manual - Dishwashers
3 Suggested Answers
  • 378 Answers
SOURCE: Servis Dishwasher Servis M4306S-C location of
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Apr 03, 2009
heatman101
  • 43501 Answers
SOURCE: my dishwasher DOES NOT HEAT UP
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
xxm
Posted on Sep 29, 2010
My dishwasher DOES NOT HEAT UP.ITS A SERVIS EASY LOGIC.It isn't cleaning properly and does not dry. I have finish dishwaher cleaner 3 times but still no better. it has salt and rinse aid in it.
heatman101
xxm
May 03, 2010 | Servis 23 in. M4306 Free-standing...
I have a servis easi logic 1300 working fine yesterday but today when i press the start button nothing i have checked the fuse and that is fine
It could be many things but the most common is the door lock ( electrical switch with three wires )
Jan 22, 2010 | Washing Machines
I need a manual for Servis M6012W washing machine
I did not have a dishwasher, as my question says I wanted a Manual for a washing Machine.
Jan 15, 2010 | Servis Dishwashers
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Washing machine not using detergent...
www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2009 | Washing Machines
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
Servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
Aug 10, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Dishwashers Logo
398 people viewed this question
Top Dishwashers Experts
