Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Does this moniter have a microphone? have a webcam to set up.
  • HP Master
  • 12,061 Answers
No, your monitor does NOT have a Mic, built in. You will have to use an external one, either in the RED Jack at the rear or front of PC, or a USB, one. (recommended)
Posted on Sep 04, 2010
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Can I use a plug in microphone to use skype on a Dell precision M70
I haven't set up Skype before, but it seems quite reasonable that if the Sound control panel is set to use the external microphone, that would work. Have you checked to see if the sound input is set to an internal microphone built into the laptop, or a line-level input? That could be your problem, especially if no such microphone is present.
Nov 25, 2011 | Computers & Internet
I have just brought a Logitec Webcam C120 and cannot get any sound. Do I have to get a microphone? When I do the sound test can't get any recording back.
Hi lynne_law ,
Many people mistakenly think that webcam can be used for audio as well as video transmission.
  1. Webcams don't usually come with microphones , therefore you would require a separate microphone for your voice recordings and voice chats.
  2. I would suggest you get a headset which would have the microphone option as well , or you can get a hand held mic.
  3. Once you get a new mic, you need to connect it to your computer by plugging in the mic in the appropriate slot , and by default the mic should work.
  4. If it does not work , you just need to change the microphone settings using the volume control option or audio settings via control panel.
Hope this helps ... ) Your feedback would be appreciated.
May 17, 2011 | Labtec Logitech 1200 Webcam
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
I have my webcam set on the monitor about 60cm from me and I can't get the microphone to pick my voice
actually the the webcam microphone have some limitation to pick up the sound signal from that much distance. better use new seperate microphone . try it, It will work, thats all........... kpfrlewajveq0aaaaasuvork5cyii%3d
Feb 03, 2010 | Microsoft LifeCam VX-1000 Webcam
After installing my webcam, my microphone is not working on my laptop. I tried it on another machine and it worked fine. Is there a setting we are missing?
Yes, it is because GearHead WC330I WebCam has built-in microphone and apparently you also installed it's microphone.
What you can do now is to select which microphone to use and disable the other one.
Got to "Control Panel" Select "Sound" icon. From the "Sound Window" select "Recording" tab and disable one of your microphone which you don not want to use.
Hope this helps you. Thank you for using Fixya.
Jan 12, 2010 | Gear Head WC330I Webcam
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
I cannot get audio and video together.
Go to Tools | Options | Audio Settings and Video Settings which is how the audio and microphone settings are adjusted in Skype.
It sounds like you might have two microphones or devices with microphones. Make sure the microphone with the webcam you are using, is selected.
Dec 20, 2008 | Logitech Quickcam Chat Webcam
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
98 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
