Question about kawasaki PVS-10921 Portable DVD Player
No power plug battery or power cord into dvd nothing no power lights on dvd player but plug the cord to the battery and charges and all lights do as supposed to
  • Anonymous Mar 12, 2014
    The power cord on the boombox doesn't make a connection when plugged into the unit so unit does not get power. Must rely on batteries only.
I have a friend that had the same problem, I opened the machine and found that the fuse had blown. Took a small piece of wire and just touched it, very brief, and every thing came on, just breifly to test, not prolonged because you don't the rated fuse for that part, I now know what is the problem, I just have to get the fuse and souder it in.
Posted on Jul 09, 2008
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
What to do when the battery wont charge on my DVD player. Its plugged into the correct cords and outlets, the light is on indicating charging. When I take out the cords and go to play nothing happens. ...
sounds like your battery is faulty return the dvd to where you bought it ask for refund or replacement or you could by a replacement battery of ebay but personally i'd return it
Jul 09, 2010 | Televison & Video
Screen is black will play on another tv with ac cords hooked up also will not charge battery
Hello
Did you see the standby light?
ok first is to removed the battery pack then plug in the power cord then see if the lights come on..
Thanks
Angel...
Sep 19, 2009 | Durabrand DUR7 Portable DVD Player
Can't seem to get my dvd player to charge.
I have this model dvd player and it has worked very well for over a year. Lately it has not had a picture but has had sound when fully charged. When the green light is on, it is charging. When the light goes off, it is fully charged (or should be). I plugged the wall charger directly into the dvd player and it works fine with pic and sound. I think maybe the rechargable battery is on it last legs. I am looking for a longer cig lighter charger cord to reach the headrest so kids can watch from backseat. I will be able to keep it plugged in to charger at all times. Hope this helps!
Apr 06, 2009 | Spectroniq PDV-70X
Charge indicator light on Protron PDV-288 portable DVD player
nahh you cant over chargee silly;; when its done, its done, it just doesnt loose battery power. and im not positive about the light.. but i would most likely assume that when the green light is on, that means its charging.. thats how pretty much every electronic works.. light on-charging; light off-no charge. sometimes it varies by different color lights.
now maybe you could help me. i have the same portable dvd player and i have the plug in that goes into the actual player.. and you know how its that weird looking end that has the light that lights up.. well what is that supposed to plug into? because i dont have anything that it can plug into and im not sure if i am missing a piece..
thanks ! hope i was helpful.
Feb 10, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Power and battery
you problay have a bad power cord you can buy a power cord at a place like target or walmart maby even radio shack
May 15, 2008 | Durabrand Portable DVD
Battery pack charge
From your description, it sounds like a bad battery pack. You may find it hard to locate one, maybe check on Ebay every once in a while, or take the pack apart and see what kind of cells are in it.
Probably not what you wanted to hear, but replacing the pack will probably fix it.
Hope that helps...
Geno
Mar 24, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Have no manual
It sounds like a bad power cord. Check your cord to make sure there are no kinks or breaks in it. I have that problem where my cat chewed the cord and now the unit cannot charge properly. Additionally, check to make certain the battery is seated properly. Try cleaning the contact with an Q-tip dipped in alcohol. Once you have done that, leave the unit powered off and see if you get the red charge light. If not, you probably have a bad cord.
Jan 16, 2008 | Zenith DVP615 Portable DVD Player
Battery charge
Simply plug the included power cord into the power input on the DVD player. Leave the unit "off". Allow to build a charge. The included power supply items are:
Flexible power supply: up to 2.5 hours rechargeable Li-ion battery,
12volt car cigarette lighter adapter and AC/DC power adapter
Jan 08, 2008 | Mustek PL-510 Portable DVD Player
kawasaki PVS-10921 Portable DVD Player Logo
42 people viewed this question
Top kawasaki Televison & Video Experts
Henry  Thomas
Henry Thomas
wayne chamberlain
Jaime Hernandez
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
