Question about Bosch 22 in. SKT5002GB Built-In Dishwasher
I am unable to open the salt drawer - it is stuck fast. I have just bought this machine and am trying to add salt for the first time - which way should I turn the drawer, or is there some other mechanism to open it?
Paper drawer stuck closed in imageclass d1150 how do I get into the printer
the drawer wouldn't open due to paper being stuck between the drawer and machine. ---www.doinggroup.com Email:market@doinggroup.com
Nov 29, 2013 | Canon imageCLASS D1150 All-In-One Laser...
Fisher paykel dishdrawer
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
Good evening. I have a Thomson DTH 5000 I am unable to retrieve a dvd from it as the drawer appears to be stuck!! any ideas as to how to sort out this problem. Many thanksja
Take the cover off the device, and look for anything blocking the DVD tray. If nothing can be seen, remove DVD by hand, and try manually pushing open the tray after pressing the open button.
CAUTION: Once the tray moves, get your fingers out of there FAST! The tray might not be able to cut you, but it will hurt like no other if your fingers get stuck in there!
Once the tray is open, push the open button a few times to open and close the tray. This will loosen any debris that may have blocked it. If it still won't move, then the motor has gone out or been disconnected. Have someone with experience working with electronic circuit boards take a look at it to determine the problem.
Hope that helps!
Feb 13, 2011 | Audio Players & Recorders
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
I bought 2 brand new players rca drc277. Neither one will open the drawer. by button or remote...???is there some code to get it started?
Hello cheekarae,
There is no code to get it started for the first time. If you bought them brand new from the store then you need to return them and get new ones.
If you purchased them off of someone, then I would almost assume they sold you bad dvd players.
The reasons for a cd tray to not come out are A. The motor that turns the gears is not working properly thus not opening the drawer. B. The gears aren't connecting properly and are unable to push the drawer out like there supposed to. (Typically you will hear some clicking or grinding noises if this is the case).
Sorry about your luck, I would look towards replacing them for some that function correctly from the get go. Post back if you have anymore questions. Thank you for choosing Fixya!
Jul 14, 2009 | RCA DRC277 DVD Player
How long does it take to make ice cream?
Not long at all, maybe 20 minutes.
Jun 02, 2009 | Ice Cream Makers
Paper drawer is stuck open
Please pull out the tray.
Check if the rear end fence is out of place.
If so, please remove the metal plate with the spring, remove the gear in the middle of the tray (below the metal plate) and reposition correctly in its place the rear and front end fences.
Then try closing the tray.
Good luck and please rate me, thanks.
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Where to add the salt
I have just moved in to a property with a miele dishwasher model no. G1220SCU. I have not been able to locate a manual and it also requires salt to be added
Oct 27, 2008 | Dishwashers
Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Bosch 22 in. SKT5002GB Built-In Dishwasher Logo
24 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
