Question about Garmin StreetPilot c340 GPS Receiver
My battery went dead on my Garmin C340 Street Pilot because it would not power up. Now battery is in and it powers up but when I turn it on it stays **** on Locating Satellites. It never locates the satellites and stays stuck.
  • rlls Sep 04, 2010
    I had already tried the reset and that did nothing.
    President:
  • 1,139 Answers
Try removing the silver bezel from the front of the unit, there should be a little indent on the top where you can get a thumbnail or blunt object behind it. Pull this gently off and there should be a little button underneath that says "Push to Reset". Push this and hopefully it will reset and start working fully.
If this does not work you could try updating it's software via the garmin website and see if that fixes it.
Hope this helps and thank you for using FixYa
Posted on Sep 04, 2010
  • Kevin Penn Sep 04, 2010
    Ok then the next step would be trying to update the software via the Garmin website. If this does not work, try removing the batteries again, leaving them out for a couple of minutes and see if that cures it. Honestly if these methods do not work then there is not anything more you can do apart from paying someone to repair it like an electronics repair company.
My Garmin Street Pilot c340 does not turn on
try calling Garmin and ask their tech department for help or go to their web site and explain problem they should get back to you right away.
Oct 03, 2017 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 street pilot
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
Mar 29, 2008 | Garmin StreetPilot c340 GPS Receiver
The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Oct 01, 2009 | Garmin StreetPilot c340 GPS Receiver
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Street Pilot C340
The only way to update the maps is to purchase new maps from Garmin and download them via the computer. The 2008 map updates are currently available, and Garmin has told me new maps will be out in a few months.
Mar 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
