You can unlock your mobile phone using the unlock code. it is the safest way to your mobile phone. using calculator, or some other method to unlock your phone it will results in damage to mobile phone. you can get the unlock code from this site www.mobile-unlocker.com at reliable cost....
If you are looking at a PUK code you need to contact your Carrier to unlock it.
There are several methods available to unlocking Samsung cellphones.
Options include Samsung unlock codes, Samsung unlock software, and in
some cases unlocking clips. The first method Samsung unlock codes is
the easiest and most reliable way of unlocking Samsung because they are
very easy to input and because our Samsung unlock codes are indirectly
sourced from the networks they are guaranteed to work. There are a few
different kinds of unlock codes, those that unlock the model of phone
for example Samsung unlock codes, and others the network for example
Vodafone unlock codes. When deciding which you will need will all come
down to the handset type, and network its locked to, if your phone is
compatible with both then go for the cheapest. The second easiest way
to unlock your phone is Samsung software unlocking. Unlock software is
usually an application that you connect to your Samsung mobile and to
the internet and or computer, which runs and then unlocks the phone.
This can range from simple to procedure to more involved, depending on
the length of time the phone has been on market. You dont need to be
extrememly computer literate to be able to use Samsung unlock software
however it does help to have standard computer with normal set up
(windows XP etc) for best and easiest results.
Hope helps.
