TDL ERROR T0008 PROBLEM TO OPENING IN SERVER - Computers & Internet
My server not configuring its settings
My server is not configuring the settings and its not opening.its opening. it is displaying the error message '2147217900 in (module mode)mode - server.:sub Get server setting (line#:40) while running ccpsrv.exe v 5.00(Build 250)
Aug 31, 2012 | OneRoof CyberCafePro Main Control Station
I have tally software but it saying that it has some error in create company tdl? wat i can do
if you have purchased the license,you may contact tally at  support.developer@tallysolutions.com for the problem and they send you the solution.
Nov 26, 2010 | Computers & Internet
Error : TDl Part : basic company
1) too expensive
2) socket or screen failure
3)Manufacturers messing up manual instructions (not clear)
Sep 05, 2010 | Computers & Internet
Hi I am receving error in creations company in tally error in tdl insufficient height to allocate
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
Jul 07, 2010 | Dell OptiPlex 740 PC Desktop
Hotpoint TDL 31. Seal between drum and door seems worn
Yes espares.co.uk will have parts and advice, sounds like you could have bearing problems...if its noisy on spin....
Apr 08, 2010 | Dryers
Error code e3
Hi;
This is the tec bulletin from maytag, read it if you can't understand it
you should call a appliance tec.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Feb 06, 2010 | Maytag Neptune Washer
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Internet sharing & mail server how make
To share internet you need a proxy software like Wingate, Winroute Kerio, MS-ISA server etc. For mail server you can use MDaemon etc
Jan 27, 2009 | Avaya Merlin Magix/Legend Control Units,...
Computers & Internet Logo
657 people viewed this question
David Payne
David Payne
