Question about Lowrance HDS 5 M and 7 M Chartplotters ()
HDS5 chartplotter keeps shutting down and restarting. this happens after about 10mins of running. could it be the engine is overcharging. the volt meter reads 15volts?
What could be the problem when I start my 2004 Subaru outback, all the idot lights come on and stay on, and the voltage meter goes to 18. Turn the AC on and lights on, voltage goes back to 14V.Turn ev
sounds Like the Body control module is goin and check your grounds for being Loose and see the could also be in the wiring Harness is a short or the dash panel is shorting out out first by used one then see what happens ther cheap
Aug 24, 2014 | 2004 Subaru Outback
New Versa 130 won't stay lit
if wired 120 volt then make sure wired correctly they come wired for 220 volt if 120 volt have to change wires if wired correctly change black and white its not rectifing
May 18, 2012 | Raypak Pool & Spa
I have a 1990 4runner 4WD. I have a white chalky corrosion that seems to be getting all over my engine, it has gotten my belt pulleys on the powersteering pump, I do not see where it is coming from but...
There are only 2 places it will come from.
1. The battery which can be cleaned down from using hot water.
2. Salt oxidation which could be coming from an external source such as the sea or factory, the corrosion is caused from the aluminium oxsidising.
Let me know if you need more help.
Thanks
Jason
Mar 30, 2011 | 1990 Toyota 4Runner
My fan keeps running after engine 01 jaguar S type 6 cylinder am i overheating
It is normal for your fan to continue to run for approximately 10mins AFTER shut off your engine. If it run's for longer than that or it drain's your battery,then you have a problem.
Feb 13, 2011 | 2001 Jaguar S-Type
When I start my outboard my A=65 shuts off, It can be turned on after engine is running
This is a very common marine electronics problem. You probably only have one battery that runs the engine and the electronics don't you? The engine when started creates a very significant draw of power when it's cranked. If the battery is old more so than ever. When this power draw happens, your machine brown's out. The electronics try their hardest to keep the voltage up but they can't because they're being starved. This can cause electronics to have memory issues, get garbled up and not perform correctly upon startup. Either add a house bank that is separate from your start battery or turn your unit on after the engine has started.
Nov 05, 2009 | Raymarine A65 Combo GPS...
Over charging
get a volt meter set it on dc scale start your engine .take meter hook it to battery it should be 13.5 to 14.5. it shouldnt go over 15. if it goes over 15 volts your alternator has a bad voltage regulator. take it back get you a new one.
Apr 01, 2009 | 2002 Ford Escape
1994 Suzuki Samurai dies when you turn the lights on
Get a volt meter and check the voltage on the battery should be around 12 to 12.5 volts.start the Samurai with it running, should be between 13.6 and 14 volts. Then while you are watching the volt meter have someone start turning on lights and accessories. If the voltage begins to drop down when it hits between 9.6 and 10.2. It will shut down the cpu and the engine will die. If this is what is happening the alternator is not keeping up, and needs the belt tightened or alternator replaced. I don't think it is the battery because you can restart the vehicle after turning off all the accessories. Mike
Jan 05, 2009 | 1994 Suzuki Samurai
Lowrance HDS 5 M and 7 M Chartplotters () Logo
53 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
