Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Need help. my zune 8gb's back button stopped working and its frozen on the podcast video screen. how can i reset this thing.
  • ashlyn_power Feb 17, 2009
    my back button stopped working
  • 8,596 Answers
Make sure the hold/lock is not engaged
Check user's manual: http://www.zune.net/en-us/support/usersguide/default.htm
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Frozen 4gb zune.
i had this problem too, i would plug the zune into the computer trough usb cord, and have your zune home page come up automatically if it doesnt click the zune software shortcut. Go to top corner and go to settings, after that go to device and syce options. finally you need to press erase all content and your zune will be clean and rebooted up. when i did this my zune turned on and was back to normal, the only thing that sucked was that it took so long for me to figure this out and i had to syce everything back on my zune agian
e mail me if you have anymore questions at zombiepoptartz@yahoo.com
i can also help you with many other microsoft problems
hope this helps
Apr 11, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
30 gig zune frozen on "ZUne screen"
if u want to fix ur frozen zune take it apart
u will need a razor and a few mini screw drivers
take it apart and remove then reinstall the battery
it should work fine after that
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Reseting my zune
Try to reset it. Press the back button (<-) and the up button ( above the Enter key) simultaneously. If this doesnt work, continue to press the back button with other directional buttons to see if this gives you a result.
Sep 09, 2008 | Microsoft Zune 2nd Generation Digital...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
46 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
