Question about Sanyo DS27930 27" TV
My tv tries to turn on but shuts right back off
  • 901 Answers
SMPS circuit problem Check the SMPS . Replace opto couplers.
Do not switch ON TV without opto coupler in circuit. SMPS will go out of control and the + DC voltage will raise and spoil the circuits.
Posted on Sep 04, 2010
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | RCA TruFlat 27F520T 27" TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Rca Model number R52Wh73 Tv is not acting right
3 capacitors on your deflection board cp150 2200uf 16v cp114 cp120 220uf 35v
Dec 12, 2009 | RCA R52WH73 Projection Television
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV turns on than shuts off right away
Try blowing the dust off mother board. Remove back. Unplug first. Then post problem again
Apr 09, 2009 | Televison & Video
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Sanyo DS27930 27" TV Logo
138 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
