Question about Samsung PN50C550 50 in. TV
MY samsung tv is stuck on store demo. how do i resolve this
2 Suggested Answers
  • 20 Answers
SOURCE: cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Posted on Aug 29, 2012
My tv model number is 60lb5900-uv how do I get it off of store demo
How To Take Your Tv Out Of "Demo Mode"
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMay 21, 2012 - There are 2 ways to take your tv out of demo mode. ... When the message, "Menu language, store demo, and time will be set", and then press ...
Samsung: LN46B650 is stuck in Store Demo mode - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI just bought a Samsung LN46B650 and it is stuck in Store Demo mode. ... If you do get prompted to choose between HOME or STORE mode (and you might), ... on the tvfor 10-15 sec(i did almost 30)...but the store demo mode wont turn off.
Samsung HDTV - Disable Store Demo Mode (UN46D6003 ...
? 0:39
https://www.youtube.com/watch?v=emPw3NkUuss
Nov 28, 2011 - Uploaded by SPSN
Jan 19, 2016 | Televison & Video
Tip
How to remove store demo pop up
To remove store demo follow this steps:
1. Enter to menu
2. Setup
3. Plug and play
4. Insert pass code (default 0-0-0-0)
5. Follow instruction until store demo and home use appear.
6. Choose home use.
7. Finish.
on Mar 29, 2011 | Samsung UN46B7000 46 in. LCD TV
Unlock demo mode
The store is supposed to handle this. See... http://forums.toshiba.com/t5/System-Recovery-and-Recovery/Stuck-in-Demo-Mode/td-p/463457 Unless this device was stolen, you should be able to get the store to resolve the problem.
Jul 27, 2014 | Toshiba 13.3" Chromebook - 2GB Memory -...
Store demo
Use tv remote to enter osd menu. Find set up.
Set location to home not showroom.
Apr 01, 2014 | Samsung PN51E450 51 Inch 600Hz Plasma HDTV
Cant get demo off on a samsung tv LE32C450E1W
Aug 29, 2012 | Samsung Televison & Video
How to remove auto visualisation n digital noise filter on and digital noise filter off features from screen of samsung lcd 21 inch....this feature is always there on the screen..........
My TV had the same problem and I have managede to get rid of it. The solution is very simple. This displays mean that your TV is in the " Store Demo" mode and any changes you make will last only for 30 minutes and when the TV is turned off the settings will change back to the normal. Whether you TV is in the "Store Demo" mode can be confirmed by pressing the "Info" button on the remote and you will see that "store demo" appears on the screen. To change this mode to the "home mode" you will have to press the "Volume button" on the TV and when the volume sign appears on the screen then you will have to press the "Menu" button on the TV (not on the remote)and hold it down for about 7to 10 seconds. This changes your TV mode from "store demo" mode to the home mode. Confrim whether the store demo mode has been put off by pressing the "Info" button on the remote to see whether the store demo sign appears on the screen. The store demo is set by sales persons in the shops so that any demonstratation/changes that they make while showing to customers will be temporary as the settings revert back to the original.
Aug 03, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Digital Noise filter off , digital noise filter on and auto visualization is always displayed in my Lcd samsung series 4 even though i turned it off in Picture options , digital noise filter is changed to...
Aug 13, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung PN50C550 50 in. TV Logo
179 people viewed this question
Jerry Greenberg
Jerry Greenberg
