Question about Gestetner DSc224 Copier
Gestetner 2713 start button stays red after warm up what is the problem
Service mode gestetner 5210
try pressing "clear"(the red C button) , "107", and hold the " all clear "(the yellow button) in succession.
hope that helps
Oct 23, 2012 | Gestetner Office Equipment & Supplies
How dop i reset e54 error of gestetner 2715?
To rest the error code > press the yellow Clear button then enter 1,0,7 then press and hold the red Stop button and hold till the screen changes. Then turn the main power switch OFF then back ON..... If the code comes back, you may have a thermister that is shorting out. Good Luck
Aug 12, 2012 | Gestetner Office Equipment & Supplies
What is a service code on a Gestetner 4502
reset (yellow button) 1 0 7 then hold stop button (red)
Nov 06, 2010 | Gestetner Office Equipment & Supplies
My Acer Aspire 5315 has problems with the screen. It does not come when I press the power button. It stays off constantly??
Hello Guest,
Have you tried pressing the Fn+F6 keys together ? That keyboard combination is used to toggle the Acer Aspire 5315 screen off and on.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
May 13, 2010 | Acer Aspire 5315-2713 Notebook
After the macine has warmed up, we push the button...
There are a couple of sensor switches on this machine to prtect user and also machine. flashing red right is the worning of some sensor is reporting unusual situation. Can I suggest you to check left side ground case is cleaned and pushed enough in to main unit, open the front upper door and check if brewing unit is staying right, water ok, having coffee, etc.
May 21, 2010 | Saeco Vienna SuperAutomatica Coffee...
Jai un probleme avec un copieur Gesttner 3220 . A l ecran il me marque le code sc542 je demande de l aide SVP
Gestetner 3220 is similar to ricoh brand
sc542 means your termistor had to be replaced with new one.
if you know the technique, switch off th copier,the open the lateral door,take out the fuser unit.
under or below it you will find 2 unit termistor with red
contact . Properly replaced both with new unit then reinsert the fuser unit in.
Switch on th copier,reset the machine to sp mode
to get into sp mode ,you have to push yellow[C] button follow by button 1,0,7 then push red button[cancel] for several sconds until the screen show sp mode.
When you in sp mode, switch off the machine,then wait for 1-2 min then switch on the copier, wa la it's working. You should try it and it save your cost.
Apr 13, 2010 | Gestetner Copier
My 60GB PS3 is having trouble starting up. Some red and green spots show up and then freezes. It took some pictures when it freezes. Any help? Is my PS3 going to need service? Is it just a HDD issue? Many...
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Functional problem code SC542-00
Enter SP mode > Clear (yellow) button > 1 0 7 > and press and hold the Stop (red) button for 3 seconds.
Then switch off and on the machine.
If error still there, probably you have a problem in the fusing unit.
Possible causes are:
Thermistor defective;
One of the fusing lamp is open circuit;
Thermofuse open;
Fusing unit connector defective; and
Power supply board.
Jan 21, 2009 | Gestetner Copier
73 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
