Question about Rangemaster Kitchener 110 Electric Range
Steam coming out of oven door - Rangemaster Kitchener 110 Electric Range
Oven doesn't let steam out
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
Mar 15, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
STEAM COMEING OUT OFF DOOR
Check either the door hinges or seal
Mar 06, 2015 | Zanussi Ovens
Had 3rd panel installed march 2014-jtp70 30 inches. now nothing is working-only the light and clock are functioning
I never really fixed the problem, but have avoided it most of the time. Tell me if I'm wrong, but when you open the door to pull out your food after cooking, the steam from the food comes up and fries the control panel, right? To temporarily fix (reset), we just flipped the circuit breaker on and off. To avoid it after that, we would hold a cookie sheet at the top of the oven door, blocking the control panel when we opened the door after the food had cooked. This keeps the steam from blasting the control panel and locking it. Instead, the steam goes into the room.
Pretty ridiculous to have to do that, isn't it? :-( I think we're reaping what we so when we outsource our manufacturing to China...
Jul 05, 2014 | GE JTP70 Electric Single Oven
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
Steam is coming off of the back right burner when oven is on
In order for the oven to work air must circulate. You may have noticed the door seal does not meet at the bottom. Air enters there and exits the chimney located in the console area. Hot air meets cooler surfaces equals condensation. Some foods have more moisture than others.
Eric
Jul 03, 2009 | GE Spectra JBP78 Electric Kitchen Range
Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Jun 30, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Leaking microwave oven???
The steam is perfectly safe, as with any other oven it has vents. Just as long as the door is shut and intact your safe.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Rangemaster Kitchener 110 Electric Range Logo
189 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Chris Hall
Chris Hall
Ismael Rodriguez...
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
