Question about Optoma LFU250E Projector Lamp for H77,H79
My Optoma H77 is great, but over the past month a shadow has been creeping in on the left side of the widescreen. It is not a straight line - wider at the top than bottom and is about 50% transparent. It has been getting wider and is now about 15% of the screen width, and the first 25% of the shadow is almost opaque. Other than that the projector works great, and has for years. Ideas? I tried to take the cover off, but I will need to get a specific type of hex driver.
  • tmunro Sep 04, 2010
    yes, thank you
  • Optoma Master
  • 19,396 Answers
Hi.
Either one of the mirrors in the light tunnel has collapsed, or there is a foreign object in front of the lens. The mirror problem is more common.
Here the same problem explained on rear projection TV, it works more or less in the same way on a projector like your Optoma:rear projection TV is displaying a darker shadow on
Posted on Sep 04, 2010
We have a Viewsonic VX2235wm Black 22" Widescreen We have been experiencing a Grey shadow to the right - damn annoying. Can you please help.
There are "on-screen controls" (electronic) on the monitor and can adjust the screen "position" up-down, left-right, wider-narrower and perhaps twist; clockwise-counter clockwise).
Try that and see if it removes the grey (empty?) area.
Brock
Sep 16, 2010 | Computers & Internet
Shadow in corners and shadow running down whole left side tv
THE MIRRORS IN THE LIGHT TUNNEL HAVE COME LOOSE. YOU HAVE TO BUY A WHOLE NEW LIGHT ENGINE. COST, $1100 FROM OPTOMA. WOULD YOU BE WILLING TO SELL YOUR SET TO ME FOR PARTS ? CALL WALT 313 220-5440
Aug 31, 2010 | Optoma RD65 65" Rear Projection HDTV
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
On my optoma H77 I am replacing a burnt out bulb with a New one. The ''TEMP'' light blinks immediatly without the projector getting up to normal opporating temp. Is there a ''Reset'' button ?
clean out the projector with canned air to get rid of the dust that could be causing it to overheat. also make sure the fans are spinning. if it still blinks, replace the temp sensor. if it overheats alot, the sensor will wear out from excessive heat.
Nov 07, 2009 | Optoma H77 Multimedia Projector
Optoma H77 - Lamp shuts off after coming on for 5-10 minutes
Hi SoonerJDP
This is indeed a warning that the hours on the lamp has been used up and that you will have to replace the lamp.
Remember to reset the lamp timer once you've replaced the lamp.
May 18, 2008 | Optoma LFU250E Projector Lamp for H77,H79
Optoma h77 parts
Hi there
You will have to locate your nearest spares dealer on the net.
Apr 12, 2008 | Office Equipment & Supplies
Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Oct 08, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
Optoma LFU250E Projector Lamp for H77,H79 Logo
83 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
