Question about Ascaso Dream Espresso Machine
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
    Habit-Forming:
  • Ascaso Expert
  • 55 Answers
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Posted on Mar 16, 2017
SOURCE: coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Posted on Mar 08, 2009
SOURCE: Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
http://www.1st-line.net/cgi-bin/category.cgi?category=review&item=i365&type=store
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
Posted on Jun 22, 2009
  • 1089 Answers
SOURCE: Ascaso Dream water leak & bad shots
Hi
Sounds like you have a leak in the system. If your handy, you can remove the top. Remove everything. Water tank included. Unplug the machine. Now turn the machine upside down on a towel. There are 2 screws behind the brew head. Remove them, then lift the machine off the top and set it right side up. Now you can see the inside of the machine where the boiler is. Do not touch anything inside the machine. Replace everything and plug the machine in. Now turn the machine on and try to make a shot the same way. This should show you where your trouble is. Once you see where the trouble is, unplug the machine. Contact seattlecoffeegear.com, or 1st-line.com. They can help.
Posted on Jul 29, 2009
  • 10 Answers
SOURCE: We just got a Via Venezia espresso maker. When I
put the rubber gasket in, then the pod basket, then the pod
Posted on Aug 02, 2009
SOURCE: Ascaso Dream heating element gone - twice
don't have a solution, but i can say the identical thing has happened to me. my heating element has burnt out after only 19 months. i don't know if i should replace it. did you buy a new machine? if so, which one.
thanks
Posted on Sep 06, 2009
Replace group head seal ascaso ARC
Hi There, If you need a group gasket for the ascaso Arc
Try links below. If machine is the older model Ascaso gasket kit Dream Arc Basic If made after 2012 Ascaso group gasket Set 2012
Jan 04, 2013 | Ascaso ARC Dark Black Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
Acaso Dream espresso machine no crema
Are you getting enough atmospheric bars of pressure? Should be around 9 or so. if not that may be your problem... also if your portafilter is pressurized (there will be a plastic disc under the screen) try removing it and see if you are getting crema then... Helped alot with mine. I also shaved the bottom to make it bottomless but that may be alot further than you want to go.
Apr 08, 2010 | Ascaso Dream Espresso Machine
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
Oct 09, 2009 | FrancisFrancis! X3 Espresso Machine
Overheating ascaso dream, and too much steam
You need to descale the machine and replace the group spring valve. It is available in a kit . Ascaso Dream gasket kit versitale version There are a number ok kits for different machnes
Jan 02, 2009 | Ascaso Dream Espresso Machine
Ascaso Dream Espresso Machine Logo
251 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
