Question about Maytag MEDC700V Dryer
I have a brand new dryer and it makes a rhythmic lub dub sound as it drys even when the dryer is empty. Anything to fix or be concerned about?
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Just got a brand new white night condenser dryer and the water light is on so the dryer won't work and there is no water in as it hasn't even been used yet
Hi, just to make sure nothing has become dislodged during transit, and to rule anything else out, the first port of call would be to remove the water drawer fully, then push it back in again, to trick the dryer into thinking it has been emptied. This way, if anything was mis-aligned during transit, where the drawer sits, it should all line up again when the drawer goes back in.
Jan 21, 2016 | Dryers
When I press the start button on my dryer it does not come on, and does not do anything at all not even a sound.. This dryer I bought brand new, and it isn't even a year old yet??? Any Ideas as to
Hi, have you checked the breaker? It would be a 220 breaker meaning a double handle or heavy duty one in your breaker box. look for one that is slightly out of line or has a small red dash showing..flip it back and forth to re-set.
Jan 08, 2012 | Dryers
Dryer is making a terrible racket, but drys perfectly.
It depends on the noise. It could be a drum roller going bad, the idler pulley, or even something caught in the blower wheel. Can you describe the noise?
Jan 01, 2010 | Dryers
I have a neptune dryer. It is making a rhythmic
I normally only comment on Electrical Dryers, but you problem sounds like something that is common to all dryers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, You will probably have to remove the top of the machine first, then remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer drys drum turns , but it makes this banging sound like there are heavy towels in it or off balance .lg dle2512w electric dryer
THERE ARE TWO ROLLERS ON THE FRONT OF THE DRYER THAT KEEP THE DRUM IN PLACE, IT SOUNDS TO ME LIKE ONE OF THE ROLLERS IS GOING BAD OR HAS A FLAT SPOT IF THE BANG SOUND IS CONSTANT AND STEADY THIS IS THE PROBLEM. EASY FIX YOU CAN ORDER THE ROLLERS ONLINE
Aug 10, 2009 | LG DLE2512W Electric Dryer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
MY DRYER IS COOKING MY CLOTHES
check your air duct. make sure its not blocked up with lint. also there could be a problem with one of your thermostats.
Feb 08, 2007 | Kenmore 62622 Electric Dryer
Maytag MEDC700V Dryer Logo
44 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
