Question about Hayward HEATER THERMISTOR - IDXLTER1930
The SF signal on my Hayward GAs Heater H400FD series needs to be replaced. I have the part but can not seem to be able to find it inside the unit for replacement. The diagrams in the manual are not sufficient and I can not see a similar part.
  • 990 Answers
Remove the sheet metal covers (top and bottom) on the side of the heater where the pipes come into the heater. It screws into the header just behind the cover. Then just follow the wires back to the front of the heater and find where they plug in to replace the unit. This will be behind the top cover on the front.
Posted on Sep 04, 2010
What should I do if Hayward pool heater is reading error code SF??
The code is SF. This is a teemperature sensor failure. Check the wiring on the electroniics bord and confirm its not damaged and that it is securly plugged in. If all is good than the temperature sensor will need placing.m either a gas fitter or swimming pool reepair center will help with this is your not comfortable replacing it
Jul 15, 2013 | Pool & Spa
Where is the temp sensor on a Hayward H300 ED2 pool heater
take off top there is a copper wired unit going into header and wire to the board
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
Hayward H400FD. Can't adjust temperature.
need new display board also check if connected to a system disconnect and try alone
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
I have a new Hayward H400FD ! How much Propane does it need in one hour of heating ??
A 100k btus burns roughly 1 gallon of propane per hour. A400k btu heater burns approximately 4 gallons (actual is somewhere between 4 - 4.18 gallons per hour.) That's assuming that the heateris running non stop during this time period.
I know your question was fairly simple and disp notrequire a whole lot of information but we appreciate you giving us somefeedback!
The Ugly Pool Guy
www.WeFixUglyPools.com
Dec 11, 2010 | Hayward H Series Pool & Spa Heater 400k...
Haywood heater has code sf what does that mean
SF is a thermistor error. Once the heater cools down it should reset itself. If not, call a service tech.
Jul 03, 2010 | Hayward H Series Pool & Spa Heater 400k...
My plumber needs manual for Hayward #H400 FDP
The P at the end stans for propane...the manual found here is for the H400FD series natural gas or propane.
John
May 31, 2010 | Hayward 400FDP Universal Series Low Nox...
SF error
IDXLTER1930
I think you must be mistaken about your heater being a millivolt heater. They have not mfg these heaters for some time. And they probably would not give you an SF error. If you have an SF error, it is a newer model with a digital board. Millivolts usually have two analog temperature dials on them and no digital readouts. That should be the part. HTH
May 20, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Mar 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward HEATER THERMISTOR - IDXLTER1930 Logo
455 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
