Question about Canon VIXIA HV30 DV Camcorder
Canon HV 30 keeps coming up with message REMOVE THE CASSETTE however when open/eject is carried out only get 2 small motor movements and then nothing and tape will not eject, any ideas ?
    Genius:
  • 1,812 Answers
Tape mechanism problems are quite complicated but they can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 04, 2010
5 Suggested Answers
SOURCE: Message reads eject. won't eject
Ihatecanon, Tried the steps you provided above with no luck. Then decided to gently smack the camera twice on the right-top side of the tape compartment. It freaking worked the first time. Got this idea by watching Eric Cartman on South Park... No, really. I read about this in another forum. It's a quick $150 back in your pocket. Just think. You sent the camera to their tech guys and paid them 150 to SMACK-IT :)
Posted on Sep 29, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon zr300 ejects tapes
I just tried the "Fonzie" fix in my ZR300 and my camera now works - cassette compartment closes all the way now with the tape inserted. It just took one "hit" to fix the prolem. I was surprised. But ericemartin's solution is worth a try.
Posted on May 28, 2008
bluelikealex
  • 52 Answers
SOURCE: TAPE COMPARTMENT KEEPS POPPING OPEN
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
Bluelikealex :o)
Posted on Dec 02, 2009
Eject cassette
sounds like already rewound or tape is caught open and have a look!!
May 15, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Cassette will not fully eject open to remove tape and will not play the tape
if you cant pull it off with a pencil or something small.. you can try with a screw driver and lots of patience to open the tape bay...
Dec 29, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Canon ZR500 won't close cassette bay
If your camcorder experiences an error, you may be presented with a ?Remove the Cassette? message. There are several reasons that this message may appear, but it is essentially a safety warning that is designed to protect the camcorder and/or tape from damage. The camcorder?s tape drive mechanism is made up of many precision components that, once damaged, may cause further problems if the mechanism continues to operate. When a problem is detected the safety mechanism is activated. The ?Remove the Cassette? warning and the camcorder?s safety mode may be activated by a variety of conditions such as: 1. Condensation is detected ? If condensation is detected by the camcorder, the ?Remove the Cassette? warning may occur. 2. Component failure ? If an electrical or mechanical component in the camcorder fails, the safety mode may activate to prevent any further damage to the camcorder. 3. Sand or grit damage ? The camcorder?s tape drive mechanism consists of many tiny gears. Sand or grit can cause a gear to jam and stop turning. This will cause the camcorder's safety mode to activate. 4. Impact damage ? If a camcorder is accidentally dropped or bumped against a hard surface, it is possible that a misalignment of the tape drive mechanism may occur. 5. Liquid damage ? If either the camcorder or the tape is exposed to water or any other liquid, a variety of malfunctions may result. Please avoid this situation. 6. Improper videotape insertion ? If a tape is forced into the cassette compartment, or if the cassette compartment is pressed down while the tape is loading, damage may occur to the tape drive mechanism. Please refer to the User's Manual. 7. Damaged or defective tape ? If a tape becomes damaged, please discontinue its use. Operational Recovery Steps Depending on the conditions that caused this message to appear, it is possible that the camcorder operation may recover. Please follow these steps: 1. Eject the videotape Insert a new or known good videotape. If the message does not persist, it is possible that the tape was damaged. If the camcorder still displays the message with a new tape, please proceed to step 2. 2. If condensation had been detected causing the Remove the Cassette warning, remove the cassette, and allow at least one hour for the moisture to dry. If the "Remove the Cassette" message continues, the camcorder may require service. Please contact Canon USA's Tech Support Center at 1 (800) 828-4040. Technical support hours are Monday through Friday, 8:00am - 12:00 midnight; and Saturday 10:00am - 8:00pm (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com.
Aug 27, 2007 | Canon ZR500 Mini DV Digital Camcorder
Eject cassette
Sir it need to replace idler unit and servicing
Mar 29, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Canon ZR100 cassette compartment won't open
Usually a chime happens when you open the plastic cover just before it opens. If you plug it into the electrical outlet does it eject that way?
Jul 06, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon md101 manula eject
yup there is sort of... you take a jewelers flathead screwdriver and push the spring back on the lens side of the cassette holder. and then on the other side there is a little hook that latches over a bump that locks it in place, you push that down and it will unlock... from there you might have to take the extremely small screw out at the top and remove the whole cassette tray...
Jun 09, 2008 | Canon ZR100 Mini DV Digital Camcorder
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
Cassette loading - keeps on ejecting cassette
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Nov 05, 2007 | Canon MVX250I Mini DV Digital Camcorder
Canon VIXIA HV30 DV Camcorder Logo
351 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
