Question about Frigidaire Heating & Cooling
My new Frigidaire FAA087S7A window AC unit picks up radio interference so I can hear FROM THE AC UNIT ITSELF, what must be a neighbor's cordless phone or baby monitor, waking me up at night. I am not kidding! This is a real problem.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Does the frigidaire model FAA087S7A
Should not be necessary as the casing is designed to drain condensate toward the back when it is installed level .
Posted on May 02, 2008
SOURCE: Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Posted on Jul 29, 2008
  • 491 Answers
SOURCE: A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Posted on Aug 17, 2009
Testimonial: "Thanks! I'll try that."
raulcvalenzu
  • 11 Answers
SOURCE: Kolin window type aircon shuts off by itself
a wiring connection in cotrol of on / off are malfunctioning
Posted on May 27, 2010
Faa087s7a frigidaire air conditioner
You need to ohm out the unit starting with the power cord.
Feb 01, 2014 | Heating & Cooling
There is a loud buz on the phone line
is there a channel selection button/. if so try selecting different channel as lots of electrical equipment can interfere with walkabout phones as can hearing aids. have u asked neighbors if they are having same problem? might be a fault on line? u can check to see if there is a fault on the line by going to bt faultfinder and typing in your phone number and they check it for u for free. hope some of this helps?
Feb 24, 2013 | Panasonic KX-TG6524 Cordless Phone
There is a very loud buzzing on the phone when talking. Does this mean the battery needs replacing?
Because the cordless phones use radio frequencies to receive / transmit what you say and hear, it also picks up other radio interference. I sujest you move the hand set or base station away from other mains operated equipment as this will interfer with your phones.
Aug 04, 2010 | Uniden Cordless Phone
I hear neighbors conversation when I use mycordless v-tech phone. why do i hear them talking? I have had the telephone company out to check the lines and they are ok.
These are called interferences. Each phone base is an antenna. You and your neighbors probably have cordless phones that use the same frequency. Check with them ann con sider buying a different phone (different working frequency).
Remember that interferences are a two-way street. If you can unintentionally eavesdrop on them, so can they eavesdrop on you (unintentionally or otherwise.) You may also consider having a spare corded phone.
Jan 04, 2010 | Vtech VT-9161 Cordless Phone
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
AC draining into neighbors window
we had this issue inside a warehouse, after carefully watching where the water exited the unit, we used a 3" pvc fitting to collect the water and then reduced it to 1" pvc and ran a drain line to a non-objectionable place. obviously if you are on the tenth story of a building this may not be an option... just an idea :)
Jul 19, 2009 | Frigidaire FAC126P1 wall/window Air...
Main TV Goes On By Itself
If this happens often enough, it would be fairly simple to troubleshoot. Remove the batteries from your remote, if the problem persists, the problem is not the remote. Next step would be to unplug power to the transmitter, if the problem persists, the problem is not the transmitter. Next step unplug power to the receiver, this should undoubtedly make the symptoms stop, but try it anyway. If it does, it doesn't necessarily mean that the unit is bad. The remote extenders work on radio frequencies. If you have the paperwork for yours, look to see what frequency range it uses. Many other devices use radio, too. Cordless phones, especially the "frequency jumpers" constantly seek around for unused spectrum space and will jump right in somebody elses' space. If you have neighbors, their equipment can interfere with yours and vice versa. I've had microwave ovens with leaky door gaskets interfere with 2.4ghz signals. The new(relatively) incursion of home wireless broadband is another local spectrum user, I can pick up as many as nine of them at once. And the lot size here is about 1/2 acre. I shudder to think what it's like in an apartment/condo environment.
Jan 07, 2008 | Radio Shack Wireless Remote Extender...
Clicking noise on all handsets upon pick-up
could there be interference ?
Severe noise interference.
• Keep the handset away from microwave ovens, computers, remote control toys, wireless
microphones, alarm systems, intercoms, room monitors, fluorescent lights, and electrical
appliances.
• Move to another location or turn off the source of interference.
Or maybe the unit is recording the calls, this is accompanied by an alert tone or click.
Mar 21, 2007 | Uniden TRU8885-2 Cordless Phone
HUM
DSL line. Possible that filters are not plugged in. When DSL service is being used on your line, filters must be installed at every jack that is in use. The DSL signal can cause static/noise, squealing (similar to fax tones) and other issues on your line. (ex. Caller ID problems). In order to avoid having this issue, the service provider gives DSL filters to all customers when they sign up for service. These microfilters must be used because they allow your phones to work properly by blocking the high frequency DSL signals from being transmitted through the telephones. DSL filters should be plugged into EVERY phone jack that has a phone. If you are not using the filters provided by the telephone company, this will cause static/noise and possibly Caller ID issues on your phones that are plugged into jacks without filters. Please contact your service provider for filter information and proper installation. Interference: Other 2.4 GHz products. Other products that use the 2.4 GHz band can interfere with the use of this phone. Items include: Radio towers, pager towers, cell phones, other 2.4GHz cordless phones and 2.4 GHz intercoms or monitors. If any of these items are in the area, they can interfere with the performance of this phone; try relocating the phone. Other 5.8 GHz products. Other products that use the 5.8 GHz band such as home networking (wireless modems) other 5.8 GHz cordless products (phones etc.) can interfere with the use of this phone. Try relocating the phone. Interference from microwave. Microwaves work on the same frequencies as the 2.4 GHz phones. If the unit is on when the microwave is running, it is normal to experience static at that time. Do not plug this phone in the same outlet or near the microwave. Environmental. Normal radio operation. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. Try channing channels. Surge protector or modem. Unplug modem or surge protector that is connected to the unit. Building structure limits range. Relocate telephone base near window when using telephone outside. Base unit located in basement or other low area. Relocate telephone base to higher location. The unit will get better reception if it is not located in a low area. Video displays, television sets and personal computers may cause interference. Video displays, television sets and personal computers can cause interference on this phone. Please relocate the phone to an AC outlet were there is no major appliance plugged in. If the base is near any of the above mentioned, locate the base to another room. Possible telephone line/service problem. Try using your equipment at a different location (i.e. friend or neighbors). If the unit functions properly in the new location, contact your local telephone company for assistance; additional charges to be incurred by customer may apply.
Feb 11, 2006 | Vtech VT 9152 Cordless Phone (VT-9152)
Heating & Cooling Logo
60 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
