Question about Powermatic 1791076BK PM1900 3 HP Dust Collector w/ Bag Filter Kit
How many amps is the motor on the craftsman dust collector 152.213360
Dirt devil jaguar pet vacuum - no power goes to vacuum
I've literally disassembled the ENTIRE vacuum. I got it for a dollar at the local goodwill with the intent on converting it into a dust collector for my mini workshop. As others have said. The suction is abysmal. I don't think it could beat a dust vac. And that's with just the motor hooked to dirt collector. No brush, no belt, no carpet adjusting. Just a motor, dirt collector and hose. Zero suction. Removed the hose, zero suction. Remove the dirt collector, solid suction. Dunno if the dirt collector is missing a part, but I doubt that based on other replies. I'm guessing all the holes in the red tube of top chamber are the issue. But I can't easily access it. I think I may end up cutting it open to try plugging some holes or some other modifications. But this vac is garbage in its original configuration
May 22, 2011 | Dirt Devil Vacuums
Subject: Eureka Tru Hepa Wirlwind Amps Model 4383. Working fine then just stopped. Later worked fine again? What is/was the problem? Does it need a new filter?? also has the # 0108017529 on machine
I'm not sure all machines are the same, but many have thermal overloads on the motor that can only be reset upon cooling, so wait 30 minutes and try again.
Secondly, my vac has 3 filters, one in the dust tray that you empty, one under where that dust collector installs and the HEPA filter on the back.
Ensure that all three are cleaned.
Gary
Feb 12, 2011 | Eureka 7619AT Vacuum
My dyson ball has no suction ... i turn it on and sounds normal for a few seconds then it sounds like it clogs then no suction but i checked the tubes theres nothing there...
Take off the dust collector , put the machine somehwere out in the open air and switch it on if the motor runs up to speed then the probelm is inside the dust collector and it is probably a blocked hepa filter
If the motor does not run clean with the dust collector removed then you need to remove the base plate and check for blockages there
Jan 25, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Trips circuit breaker when turn on.
This tool needs to be on a 20 amp breaker. And not a GFCI. GFCI breakers are very sensitive to high amp start up motors.
Nov 04, 2009 | Delta 50 - 760 1.5HP Dust Collector
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Dust collector
dust collectors usually work off the motor via a fan. Either the fan is broken or the bag is blocked up.If the bag is too dirty inside you don't get any airflow through the bag which can stop it collecting. A good wash should do the trick
Aug 29, 2008 | Porter Cable 3" x 21" Electronic Variable...
Powermatic 1791076BK PM1900 3 HP Dust Collector w/ Bag Filter Kit Logo
83 people viewed this question
Top Powermatic Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Powermatic Air Tool and Compressor Expert? Answer questions, earn points and help others
