Question about Intel Core 2 Duo Retail Boxed E7200 Processor - 2.53GHz, 3MB Cache, 1066MHz FSB, 45nm Wolfdale E700 Boxed Processor
My system randomly shut downs sometimes, my core temp is some times reading 90,95
    President:
  • 2,571 Answers
This is very high, 70 to 75 seems the safest temp.
I would remove the HSF, clean the cpu. and refit the HSF with new thermal paste.
If your not sure how, there are plenty of Youtube vids showing the fitting of CPU's
Posted on Sep 04, 2010
What causes compressor to work fine then shut down and not come back on for an extended amount of time?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
Jul 08, 2015 | Frigidaire FRA296ST2 Air Conditioner
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Acer Aspire M5100 shuts down randomly. Sometimes lots of programs running, sometimes none. Fans have always been loud, and they still are. I don't know how to troubleshoot, I am a graphic artist and I need...
Would need more detail but sounds like it is a problem with your processor overheating because of ur fan situation. To be sure of this download a program such as speedfan to gauge your temps.
Mar 18, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Computer completely shuts down. Sometimes it doesn't start up. Other times, it starts up and randomly shuts down. Did full system restore and still have problems with it turning off. Their tech support has...
Either this is a overheating problem, need CPU fan for this. If this doesn't work, then it could be a hard drive problem. If not, then motherboard is probably going bad.
Feb 19, 2010 | X2 ZT Systems Athlon 64 4800+ Dual-Core...
94 Chevy Suburban runs 1 minute and shuts off like
This is an electronic engine control problem do u have any system fault codes? u need to check them, here is how to do that, go to the link.
http://check-engine-light-codes.blogspot.com/2006/03/gm-1983-95-vehicles-obd1-codes-self.html
Feb 02, 2010 | 1994 Chevrolet Suburban
Acer aspire 5630 laptop keeps shutting down
It sounds like someone has suggested that overheating may have caused the random shutdowns (which is quite plausible). There are a few tools that can diagnose what is happening:
  • Temperature: I use SpeedFan (http://www.filehippo.com/download_speedfan/) to discover the temperature of my cpu. My Acer 5630 is usually doing 50 to 60 degrees. Anything higher than that could cause the random shutdowns (I've seen it happen on other laptops). If you download this program, don't muck around with the settings (as it would advise you not to anyway), just look at the temperature readings (eg. core 1 core 2)
  • I keep a cpu usage meter on my sidebar (http://gallery.live.com/liveItemDetail.aspx?li=587ef54f-e121-418b-b258-e583e105a0d6). It keeps an eye on the CPU usage so if i see it say 100% cpu usage then I suspect some software is inappropriately consuming resources.
Treatment of overheating would be to find the offending software and manage it or remove it. If it is not software at fault, then it may be that there is too much dust covering the ventilation (Your acer may be old and you may hear your fan increasing speed and the performance struggle sometimes). I opened up my one and found dust build up from the radiator all the way to the fan! (it was like around 1cm thick in some places, i wish i took a picture)
Another reason for random shutdowns is the integrity of the power switch or the lid sensor. My computer got rained on once and randomly shut down. It took a while of cleaning it with Circuit board cleaner from Repco (I had to open the panel that covered the power button and spray it). It got better everytime I cleaned it and now it reliably stays on (actually it randomly turns on now haha)
Jan 02, 2010 | Acer Aspire 5630 Notebook
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
Randomly shuts off
I am having the same problem along with many others, seems to me that this board is a waste of time. PC repair tells me that it is due to the "system timer" how this is fixed, I dont know yet.
Checking for bios drivers at the manufactures web site at this time, will let you know how it turns out. sorry cant b more help
May 15, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Intel Core 2 Duo Retail Boxed E7200 Processor - 2.53GHz, 3MB Cache, 1066MHz FSB, 45nm Wolfdale E700 Boxed Processor Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
