Question about Williams-Sonoma Stick Blender Handheld
Extra blades for the william sonoma hand held magic wand blender
Motor won't run
Go to the manufacturer website and maybe you can have or get warranty repair. It could also still be under warranty.
Jul 11, 2015 | Magic Bullet Nutribullet Blender
Making meringue with hand held bamix
Use the A blade and make sure whatever you are mixing the egg whites in is scrupulously free from any grease etc. Make sure the bowl is clean and dry before you use it.
Best wishes
Sep 20, 2012 | Bamix Deluxe Handheld Blender
I inherited a hand-held blender; the stem is not detachable. How do I wash it?
Just blend warm water with a litle soap and then dry it with a dry cloath. Remeber to remove the socket when you dry it out for extra safety.
Aug 14, 2010 | Hamilton Beach 59735 Handheld Blender
The blades on my blendtec jug are stiff, any way to loosen them?
What you need to do is turn them by hand each time you use it, before you put your food in. Sugars and other deposits are often left around the blade assembly when you mix smoothies and stuff. Often this sugar is difficult to clean. Turn them by hand first to break the sugar molecules, then when you are done I would add 2 inches of water and a drop of soap. Run it for about 20 seconds and rinse. That should help the next time you use it. It also helps to use it daily. It keeps the molecules from hardening.
Jul 28, 2010 | Blendtec Extra Carafe / Jar for the Total...
How do you take the mixer off of the wand to clean it?
YOU DO NOT NEED TO ,TO CLEAN MIX WATER AND CLEANING FLUID AND BLITZ THIS UNTILL CLEAN.
Oct 13, 2009 | Williams-Sonoma Stick Blender Handheld
Need replacement blade for Russell Hobbs hand mixer
go to this page http://www.russell-hobbs.com/parts.shtml and order what you need directly from Russel Hobbs.
Please mark this answer as a fixya! thanks
Mar 18, 2009 | Russell Hobbs RH-HB3 Handheld Blender
Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Williams-Sonoma Stick Blender Handheld Logo
721 people viewed this question
Top Williams-Sonoma Blenders Experts
eyecam
Ross Keen
Are you a Williams-Sonoma Blender Expert? Answer questions, earn points and help others
