Question about Gateway FPD1760 17" LCD Monitor
Gateway fpd1760 monitor loses picture after 2 seconds...
I have had this monitor for about 3 years now. I have had no problems with it until one day the screen went black. If I turn it off, then turn it back on again, the picture stays on for about 2 seconds then goes black. The power light stays blue the entire time, so I know it is not in sleep mode. Is the monitor shot and I need to purchase a new one? Or can I replace some of the parts? Is it a problem with a video card? HELP!!!
  • 1 more comment
  • Tinkerburkey May 22, 2008
    Same problem only the button does change colors and I know it is not in sleep mode I just turned it on.
  • swa10plt Oct 19, 2008
    I have a FPD1760 that is on for 2 seconds then goes black. Any way to fix or is it time for a new one, and what causes it.
  • chell-e Apr 01, 2009
    Screen flickered two days ago, but came on. Yesterday it would not stay on, just as the other person said, for like 2 seconds and gone again. No signal was popping up except i could hear things popping up in the background, just couldnt see them.
    Scholar:
  • 45 Answers
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Posted on Jul 14, 2008
  • Victor Castro
    Victor Castro Sep 11, 2008
    Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
    Easy Fix REALLY EASY FIX
    (inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem Like the solution it is a component gone bad. Replace it and you will have a spanking new looking nice monitor working again. :)
    ugh if only I was able to send you this before the "best solution" was selected, :(
This is a common problem with the Gateway 1760 series LCD monitors. The Capacitors on the Inverter/power board are known for failing. If you are lucky, replacing the capacitors will fix the issue. Generally, the 1 Very Large capacitor on the power board is fine, the smaller ones are much more prone to failing. On occasion, the board develops further issues as the capacitors start to fail, and the whole power board must be replaced. The rest of the components are usually just fine, and replacing/fixing the power board will return the LCD to working condition. As for the backlight itself failing, these monitors have FOUR CCFL's (backlights) and one of them failing will usually cause the one paired with it to quit functioning as well, leading to only the top or bottom set working, but this can be tested with a spare backlight from a dead/cracked laptop screen.
Posted on May 02, 2010
  • akgeeks May 02, 2010
    Edit: As a further note, opening the monitor up is a pain. You'll need a razor blade to pop the plastics loose. To start, remove the kickstand first then remove the other 6 from the back and bottom edge-back. Remove the screw lock-downs for the monitor cables <4 of these>. Flip the monitor on its back, and gently pop the silver frame off around the LCD with the razor blade, starting from the bottom, and pop loose the Left edge first, being careful when popping loose the right edge, as the power button/adjust buttons are attached there and there are several thin cables under the right edge of the LCD frame. These cables can be left attached to the LCD frame, or simply remove the 4 screws holding the two Button plates to the LCD frame, and let the plates hang loose. The LCD is held to the back plate by 4 screws. Remove these, and lift the LCD out of the back plate well ONLY AN INCH, as there are 5 cables under it attaching the LCD to the circuit boards inside the monitor. Prop the LCD up a bit so you can see under it, and use forceps or needle-nose pliers to pop loose the 4 CCFL plugs. The LCD monitor cable can generally be gently tugged free from its socket with fingers. Set the LCD aside and you have access to a small grey box, with about 6 screws holding a plate over the top of it. TWO of these screws are not like the others, so make sure you mark these two with a marker to show where they came from. Remove the top cover plate, and you will see two circuit boards. The top one will be the power board, which plugs into the bottom one, the video board. Easy to tell as the Power Board is the one the external power cable plugs into. There are 4 or 5 screws holding the power board down, remove them and pull the board straight out, taking care to unscrew the ground wire underneath it FIRST. Flip it over and you will see the capacitors right off. If they are bulging or leaking. there's your issue. Even if they are not, they may still be bulging out the bottom or burnt out, so try replacing the capacitors before replacing the board. Reverse order to re-assemble.
I have one of these monitors... the problem with mine is the backlight died
Posted on Oct 16, 2008
Sorry, no solution here only because my friend has the same problem and I'm trying to help her figure it out. From the things I've read so far today, I'm going to tell her to buy a new one at Costco. For the price, she can actually get a comparable one but with a huge screen.
if anyone else knows if this problem is fatal, I hope you post. It doesn't make sense to pay someone to fix a problem that costs almost as much as purchasing a new monitor.
Posted on Aug 13, 2008
  • 981 Answers
There just aren't that many economical repairshops, I take it? It's probably turning itself off because it thinks something isn't right (possibly because that thing isn't right.) But you didn't change much, right?
Even so, solid-state components overheat (unlikely in 2 seconds) and/or wear out (we'll go with this one). Famously, electrolytic supply capacitors can go bad, or electrical leakage from dust can cause voltages to go off spec, or the backlight can go bad (drawing more power than it's supposed to, say.) These things are very fixable in general, you just get to narrow it down so it's not a big deal.
It's not like newer monitors aren't improved in contrast ratio, color consistency, view angle etc. (So you don't lose contact with people while fixing the old one, if it's crucial and they're remote or your cellphone plan is unforgiving or something.)
Posted on May 11, 2008
I want to put my laptop and connect it with Gateway monitor. What type of plugs do I need?
Spec of the monitor http://www.dealtime.com/xPF-Gateway-Gateway-Monitor-FPD1760
It will need the VGA cable (3-row/15-pin D-SUB), you need to look at your laptop monitor port to see what you have for the output.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
And you will need to set the laptop video signal to be at the native resolution of this monitor, which is 1280 x 1024 @60Hz.
Sep 10, 2010 | Gateway FPD1760 17" LCD Monitor
This monitor is great. Just recently, after 3
It seems so.
1. Change the monitor cable and see if this still happens
2. Attach this monitor to another PC and see if this still happens
If it is still happening, then yes, it seems that it is failing.
Mar 14, 2010 | Gateway FPD1760 17" LCD Monitor
Gateway fpd1760 lcd monitor no power at all the blue led clicks on for 5 seconds the screen flashes for a milla second then nothing
check if the signal cable has been plugged in properly at the back of the screen and at the back of the computer.
if you have another computer or laptop,.check if the screen works fine with it.as this could even be a boot up problem with the computer
Feb 04, 2010 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Your graphics card is not working propertly buy a new one.
Mar 15, 2009 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Problem with FPD1760 Gateway monitor
sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
Jun 18, 2008 | Gateway FPD1760 17" LCD Monitor
Monitor won't turn on.
Does the cord plug directly from the wall into the monitor, or is there a power "brick" adapter between?
If there's a "brick" listen to see if the hissing is coming from the monitor itself or the brick. If the hissing is coming from the brick you may just need a new power adapter.
If there's no brick or the hissing is coming from the monitor, the monitor probably needs repair. With the price of LCD monitors these days compared to the price of labor, you're probably better off getting a new LCD monitor. Just make sure you take your old one to a proper E-Waste facility so it doesn't pollute the environment.
Apr 05, 2008 | Gateway FPD1760 17" LCD Monitor
My Gateway FPD1760 Won't turn on.
Inverter or Inverter boards Blown.
Hope this helps.
Mike @ compurepair.
Feb 23, 2008 | Gateway FPD1760 17" LCD Monitor
Gateway FPD1760 17" LCD Monitor Logo
1,122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
