Question about Gestetner DSc224 Copier
Im getting this code e-06 on my 5306b copyprinter once i press start button
2 Suggested Answers
  • 1297 Answers
SOURCE: CopyPrinter DP 2540 will not ON when power button is pressed, I need your help.
Verify the fuses in the supply board and the covers actuator contact.
Posted on Mar 18, 2013
E22 code
E - 22 Scanner home position sensor error.Possible causes:
scanner home position sensor failure
scanner motor defective
incorrect scanner ddrive wire position
Remove the exposure glass and verify the wire and the sensor actuator.
Turn DIP switch 101 - 1 ON and press START key to run free the scanner.DIP switch is located on PWB board in rear area,remove the rear cover.
Feb 07, 2013 | Gestetner - 5309L CopyPrinter Copier
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
I have an rca remote modle rcu730 and i lost the guide and im trying to program my remote to an symphonic tv and i tried to codes that the computer keep 064 076 and neither of them seem to work do you kno...
Programming using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Feb 01, 2010 | RCA Universal Remote Control
I have a living solutions jumbo remote and im trying to program it but it does not have a code search button like every manual i seem to find on the internet says to hold what do i do?
Here are the code search instructions for the Innovage Jumbo Remote that you are looking for.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 06, 2009 | Innovage Jumbo Remote Control
Stupid remote
the procedure for those remotes is pritty much the same, press and hold the code search key untill the light remains lit, then press the tv button, then enter the code.If you still have problems try their website.
Sep 12, 2009 | Philips Magnavox Learning Universal Remote
Black spots and lines on papper
Hello sir; Only thing you need to do is change a drum cartridge.
Jun 03, 2009 | Brother DCP 7010 Multifunction Laser...
Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Oct 27, 2008 | Ricoh Aficio 250 Copier
Setting The Clock
Set the display to time by pressing the tittle button. once time is displayed, press tittle button and hold until the time starts blinking. now adjust hour using arrow keys. now press mode once and use arrow keys for adjusting minutes. press mode again. now the time is set.
Alex Victor
Jul 01, 2008 | Alpine CDE-9841 CD Player
Sticky Buttons
i need some help with this too, my psp is doing the same thing, can u please help me out too?
May 28, 2007 | Sony PlayStation Portable (PSP) Console
51 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
